Question about Kenmore Dishwashers
Middle spray arm dripping but not spraying - Kenmore Dishwashers
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa,
Based on your description I`d suspect a plugged wash pump.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It is not really referring to the heating issue, or maybe even your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Posted on Aug 06, 2010
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 111 Answers
SOURCE: upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Posted on Dec 18, 2008
  • 254 Answers
SOURCE: SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Posted on Mar 09, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
  • 30 Answers
SOURCE: du1145xtpq top spray, and upper spray arm don't
sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
Posted on Dec 03, 2009
The middle spray arm isn't rotating
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Frigidaire Dishwashers
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
Frigidaire dishwasher top spray arm only drips the water out. top spray arm doesnt spin
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 14, 2010 | Dishwashers
Water is dripping from the door
try liffting the front legs of your dishwasher a bit so it angles more to the back and check your spray arms make sure they haven't cracked on the seem
Mar 29, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
GE GLD5800L Middle Spray Arm is Not Spinning
The middle arm may be missing an O-ring at the back of the dishwasher.
Mar 23, 2009 | GE GLD5800L Dishwasher
Rotory spray arm
The most likely cause is that some of the holes in the spray arm are blocked. Candy wrappers, tooth picks, seeds, nut shells or other food objects can get into the spray arm and block up the holes. If you can't get them cleaned out you may have to replace the spray arm.
Nov 08, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
113 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
