Question about Leviton Combo 2 Switch Single Pole - 5224-2A - Almond
2toggle switch--2wires each side ground --wheniput in new switch-- both lights work off one toggle--nothing on other toggle--instruction tlks of breaking off fin but doesnt look like my setup--ihave 4 separate wires not 3
  • Al Kupchella
    Al Kupchella Aug 06, 2010
    I can't tell if you mean you have 4 pig-tail wires on your switch or 4 wires in the wall. But I will assume 4 pig-tail wires on the switch and 3 wires in the wall. If you are certain there is no fin or tab between two screws on either side of the switch, then connect your hot wire to both of the pigtail wires on one side of your switch. Connect each of the other two wall wires to one pigtail. (That's one each.) If you are not certain which wall wire is hot, get a non-contact voltage detector. They are less than $15, are about the size of a pen, and are the greatest thing since sliced bread. Good luck. Be safe.
    Scholar:
  • 130 Answers
First thing that needs to be done, is to find out which pair of wires go where. Since you had these lights working (somehow), Switch off the breaker or unscrew the fuse that operates these lights. Once the lights are off you can now disconnect all the wires from that switch. Keep all wires separated, and away from ground. You mentioned that you have a equipment ground (green or bare wire). Hopefully this goes back to the panel. With a continuity tester or VOM (make sure it is in OHMS), place one lead on this ground and the other lead on any white wire. if it reads almost zero ohms, then this wire is a neutral wire. If not, it either indicates that you have 2 hots and 2 switchlegs, or you may not have continuity back to the panel on the ground wire. Another approach would be to make sure no one but yourself is in the area. After removing the wires from the switch and isolating them, again making sure no one is in that area, turn the power back on and place the VOM on voltage (Make sure the leads are in the proper locations on the meter) Place one lead on ground and with the other lead touch the individual conductors. The one(s) that reads 120 volt are hot. To make sure you have the proper conductors, unscrew both bulbs, to make sure you are not getting feedback.if you have 2 hots then the mating pair in the able goes to the light fixture. you would need to remove the fin because the fin is for a 3 wire application.
Posted on Aug 11, 2010
I have a 1984 Shasta 2100 . There is a 110 volt receptacle on exterior. There is less than a volt going to it. All other recepticals are fine. I have replaced the recpit all.
is this when the shasta is plugged into a 110 volt hookup or are you running a generator try turning everthing off and taking a 110v extension cord and plugging it into the plugin in question then go inside try any of the 110 v lights tv plugs ect is there connection there ok then plug is working what about breakers fuse ect. you can take the battery loose and turn everything off take a car battery hook 2 wires to it,(2wires) plug one into the one side of plug (not ground) and hook the other up to a wire hooked to the ground' then go inside take a 12 volt test light try and find if the voltage front that side is at fuse box if so note it ',if not switch the wire you hooked to the other plugin prong hole (not ground) do same test inside with test light okay is voltage there you can assume something from such measurements but not from the 1 volt it is inconclusive as to whether running a new wire is necessary or not
Mar 11, 2018 | Cars & Trucks
I'm installing a dimmer switch to control two lights. I have three black wires attached to the original light switch that is a single pole. When I hook up the dimmer switch it does not work.
You have either wired it wrong and destroyed the dimmer or just wired it wrong.
I'm guessing that one wire is hot and 2wires go out to the lights.
The hot wire should be on one side of the switch and the other 2wires on the other side.
Here's a video -
Dimmer Switch Installation single pole By Everything Home TV
Sep 17, 2017 | Electrical Supplies
1996 Saturn Fan won't work
-Why you want to hook up a switch to the fan...? You want to turn it on when you want?
-No Problem. Here some basic installation.
-Connect the hot wire to the positive (+) battery terminal.
-Connect both left over wire to the switch. Then connect 1 wire from the other side of the switch to ground. you should be good to cool down.
Good lucj
Mai
May 16, 2017 | 1996 Saturn SL
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
How do i bypass the park brake
Add a toggle switch. Connect one side of the toggle switch to the light green parking brake wire and the other side to ground.
Sep 27, 2010 | Kenwood DNX5140 Car GPS Receiver
I am replacing a 3 way light switch with a dimmer switch. The existing switch has the green ground, two black on one side and a red on the other. The new dimmer has the green ground, two red and one black....
There is no universal convention on the color coding of wires for three-way switches, other than green always being ground. Fortunately if you wire it wrong you won't hurt anything, it just won't work right. Two wires are "travelers", they run between one three-way switch and the other. The "travelers" were attached to opposite sides of one end of your old switch. From your description, one is red and one is black. (These two wires are interchangeable, except that in one position both toggles up or both down would ON. In the other position one toggle up and the other down would be ON.) The "third wire" was attached to the other end of the old switch and is black. If you can't tell by just looking at it which lead of the new switch is alone at one end of the new switch (and is therefore mate for the "third wire"), you can just try the combinations. Assuming you still know which black wire is your "third wire" there will only be 3 combos.
Jul 27, 2010 | Cooper Wiring Devices Three Way Grounded...
Dvd player to work while in motion
This can be done with a toggle switch or a relay.
**Toggle** Connect one side of a toggle switch to a ground and the other to the light green wire on the unit (parking brake input). Once the vehicle is started, just flip the toggle and apply ground. Taa-daaah.
**Relay** (see image)** This will bypass the parking brake automatically every time.
Aug 03, 2009 | Pioneer AVH-P4000DVD Monitor
3 ways not wired correctly
Im not sure if you know what you got yourself into but i hope this helps. Sorry for all the words but this does take some reading if this is new to you.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Dec 13, 2008 | Electrical Supplies
VR3 VRVD630 dvd bypass instructions/codes
I also just bought a VR3 DVD -CD PLAYER MODEL# VRVD630 ALL I DID WAS CONNECT THE BROWN PARKING BREAK WIRE TO THE GROUND WIRE THAT LETS YOU WATCH DVD WHILE DRIVING HOPE THIS HELPS
GOOD LUCK STROUP
Nov 27, 2008 | Jensen VM9510 Car DVD Player
Leviton Combo 2 Switch Single Pole - 5224-2A - Almond Logo
112 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
