Question about GE Refrigerators
I have a GE Profile refrigerator model PFSS5PJXA SS, French doors with bottom freezer and water dispenser, no ice, on right door. A small rubber disk fell of from behind the paddle that the glass is pressed against o dispense water. With the disk missing the water dispenser does not work. How do I reapply the disk? I will need to remove the paddle to get at the location where the disk needs to go.
I removed the control panel (2 tabs under the front edge) removed the 4 screws holding on the paddle assembly and removed the assembly. The disk is glued on the back( I used super glue). If it happens in the future I would try to glue it on without removing everything. If you use a mirror you can see the detent where the disk mounts to the paddle and glue it back on. The disks function is to push on the switch that is located behind a gray rubber panel behind the paddle.
Posted on Sep 27, 2010
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Refrigerators Logo
373 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
