Question about Ovens
I have a zanussi gas cooker with electronic timer and i want to know if I can reset it as the automatic function has been started and I can't get the unit to do anything now?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
If a 3 button timer press the centre button once, then press the - (minus) until the display reads 0000. leave for 10 secs till time of day returns. it should work now. if not this type include the model no and ill give correct instruction.
Posted on Aug 06, 2010
  • Mike King
    Mike King Jan 26, 2013
    Same problem with my Zanussi ZCG7551XN. Any ideas? Thanks
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
My oven wont come on and i know there is a problem with the electronic programmer, can i reset it or not use it at all
If you cannot reset the oven timer, then it will not heat the oven.
This being the case, then it is possible in some cases to bypass the timer, or the alternative is to to replace the timer.
Jan 25, 2011 | Zanussi ZBF360 Electric Single Oven
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
    Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
    Hope this helps.
    Jun 13, 2010 | Zanussi Ovens
    Zanussi Built-In Oven Clock keeps resetting?
    The 1000uF/10V condensator in the timer unit has to be replaced.
    Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
    Ovens Logo
    94 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
