Question about Toshiba 50H72 50" Rear Projection Television
TV Toshiba 56PW8
When I power on, sound o.k. picture no, when I power OFF, just second lamps light. Thank you for answer on mail intec@seznam.cz
SOURCE: No picture, hear sound, television will shut off after a few seconds.
Take out the bulb (back left hatch door) look to see if the element inside the bulb is broken or blackened - (replace bulb) if the bulb looks OK then it's the ballast that fires the bulb (service call).
Raf
Posted on Nov 30, 2007
  • 184 Answers
SOURCE: Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
Posted on Feb 14, 2009
  • 276 Answers
SOURCE: Toshiba 72HM196 TV. No picture but sound. Comes
la comvergencia tiene que revusar esa etapa porque es muy important
Posted on Aug 26, 2009
roety
  • 585 Answers
SOURCE: Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 09, 2009
  • 1039 Answers
SOURCE: 42" dlp tv has sound but no picture, replaced lamp already
Replace the ballast.
Posted on Dec 05, 2009
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Hi my name is Eric,
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba 44NHM84 has no picture just red flashing standby light
during transportation your TV was suddenly shock. then causes your TV lose connection on main circuit board. trust me!
May 21, 2009 | Toshiba 44NHM84 44" TV
50V500A
if the lamp has dies alot of the time to can look inside the lamp and see if it exploded (not always) do you get blinking lights?
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV MAXIM 11-54
I can supply a repair kit for that for £40.00
Plus delivery
Or a new PSU for £98.00
Plus delivery
www.FixMyPlasma.co.uk
Nov 26, 2007 | Televison & Video
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 50H72 50" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
