Question about Vacuums
The belt does not appear broken, but the beater bar is not turning, and there is little suction. The debris cup is empty and the filter is clean.
  • 27 Answers
Clean both ends of roller .hair ect.get wrapped around down where the axle is
Posted on Aug 06, 2010
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
Susan:
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
Beater brush stuck on (keeps turning) in upright position and no hose suction with Hoover U5753-900 WindTunnel Bagless Upright Vacuum. I have tried adjusting the brush level up and down and moving the...
HI, it's Jim from Crucial Vacuum!
Your Hoover may be losing suction in the hose and having an issue with the brush roll due to a clog within the vacuum, or possible debris stuck on the brush roll itself. Here's some tips that will help.
First off, if your brush roll just keeps turning be sure to turn off your vacuum before examining it. In regards to the lack of suction in the hose there may be a clog in the vacuum itself.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction, for the hose as well.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Lets look at the hose itself. Stretch the hose out entirely to see if there are any clogs within. A handy way to unclog your hose is to use a broom handle or coat hanger. Make sure the coat hanger is a plastic one. You don't want to tear the walls of your hose.
As for the brush roll itself. Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. Also, manually spin the brush roll to see if there are any clogs or debris stuck within.
You can purchase replacement parts for your Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+windtunnel&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 14, 2014 | Vacuums
Beater bar not working. suction not working
Check for a broken beater brush belt. Clean the beater brush, clear of all debris and add some WD40 at each end where the rubber holders are. Turn beater brush by hand to work the WD40 into the axle. Reassemble making sure the belt is on correctly. This should also help solve the suction problem as well.
Oct 01, 2010 | Dyson DC07 All Floors Bagless Upright...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Hi the suction on my dyson hoover has gone very poor. I have cleaned all filters but suction is still pretty poor.Is there anything else i can do?
your problem with Dyson is the reason why a lot of them end up in the trash. here is the link to an article that will help you locate the cat fur, or hair or other debris that is lurking inside your machine and causing you to loose suction
http://www.insanityideas.com/blog/Thursday-24-March-2005
Aug 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
It has no suction...last couple of times while using the vacuum it would cut itself off. If I tried to use it the next day it would do the same thing
You vacuum is probably plugged up. Flip it over, beater bar up, and remove the plate that surrounds the beater bar. The beater bar needs to come out next. If the belt is good, it will be a little hard to remove. The beater bar sits in sockets that then go ilto the vacuum frame, so note how they come out as you ease the beater bar out and slip the belt off of the bar. There's a cavity behind the beater bar where the vacuum picks up debris. Stuff hangs up there, and you'll need to remove whatever is plugging you up. While you have everything open, give it a general cleaning. Remove anything wound around the beater bar, etc., and reassemble the vacuum in the reverse order.
Best regards --W/D-- -- please feel free to rate this solution - thanx!
Aug 04, 2009 | Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Assuming that the vacuum will run, remove the bag and check the discharge to the bag from the machine for debris. Also check the suction to the vacuum blower by removing the beater bar cover plate and beater bar. Inspect the belt. While the bar is off, inspect the suction hose behind the beater bar. This is where I usually find the debris.
Regards, --WoobieDog--
Jul 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
