Question about 3Dlabs Oxygen GVX210, (64 MB) Graphic Card
The 4X override and fast-writes can't be supported totally in XP..........
Now, the card just run in AGP 1X speed and fast-writes has supported but be stop(i don't know why~?) in my XP system....
SO~.!...when i work too more and the mouse move too fast...xp is easy crached and show out the blue screen...then system is down...only reboot it...
i use TYAN K7 S2468 motherboard and AMD Dual MP 2400+ CPU to suit with this Oxygen GVX210 graphics card.
in BIOS was actived the both function 4X override and fast-writes...
and updated the AMD 762/768 chipset driver...
i missing somethings or do some wrong setting~??
if, i want to change graphics card..
wildcat4_7110(AGP3.0...supported speed 4X/8X)...
it can running well in TYAN K7 S2468 motherboard(AGP2.0...supported speed 2X/4X)....
please give me a guide to fixed ..........
  • 40 Answers
First check the bios version and tyan's compatability site for the video cards support...
if all checks well and the bios has been updated ...
then: try running a ps/2 mouse and verify the usb components is not the error....
be sure you have support for 1.0 and 1.1 usb activated for a mouse support.. and keyboard mouse options on in the bios...
is it a mouse error ... or video card error... check for updates on the manufacturers of the mouse if usb...
Posted on Sep 28, 2009
Which graphic card can I use for d865gbf board
Any card that uses a PCI slot or a AGP slot.
AGP Spec: Universal 0.8 V / 1.5 V AGP 3.0 connector supporting 1x, 4x, and 8x AGP cards or an AGP Digital Display (ADD) card.
Ref: http://downloadmirror.intel.com/15207/eng/D865GBF_D865GLC_TechProdSpec.pdf
Dec 20, 2012 | Computers & Internet
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
What AGP graphics card is compatible with AGP
AGP 4X (1.5 Volt)
http://www.firingsquad.com/hw/1719/Iwill_P4S/
Suggest you use a graphics card that is AGP 4X/8X
Example, ( Not an advertisement for graphics card manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Jan 14, 2010 | Computers & Internet
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
Oct 05, 2009 | EliteGroup K7SOM Motherboard
Problem for my video card drivers
Go under your start menu and click on windows update, and when it pulls up internet explorer click on custom install and you'll see all the updates click on hardware and see if windows can install the driver.
Jun 17, 2009 | Ultra ATI Rage 128 Pro Graphic Card
Compatability
You have an AGP expansion slot for a graphics card.
(Accelerated Graphics Port)
It uses either 1x, 2X, or 4X graphics cards. Since the only AGP graphics cards out there are 4X or 8X, the 1X, and 2X are moot points. (They were also Junk anyway!)
Your AGP graphics slot only supports AGP graphics cards that are 1.5 volts. There are AGP graphics cards out there, that are Universal. Universal in that they will run as AGP 8X, (.8 volts), or AGP 4X, (1.5 volts)
This is an example:
Don't expect to play the high end new intense games with this. I'm afraid you'll have to update your motherboard, processor, ram memory, and a better graphics card to do that.
(Example? XFX Nvidia nForce 680i LT SLI motherboard, Intel Core2 Duo E8200 cpu, Corsair XMS2 PC6400 ram memory, 1GB x2 of them, (DDR2 at 800MHz), and XFX Geforce 9800GTX+, vid card. (Plus OCZ SteathXStream 600W power supply)
This won't break the bank, and will slam some games to the wall!)
Jun 05, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
MSI motherboard model 6734 AGP interface
Looks like your motherboard is a MSI KM4AM-L detailed here:
http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=572&maincat_no=1
If so, then it has an AGP slot which will run at 4x and 8x.
Remember to check the BIOS settings after you install it to make sure it is set to 8x, if that is what your card will take.
Sep 22, 2008 | MSI KM4M-L Motherboard
About graphics card
Your motherboard supports AGP graphics cards at 1x, 2x, and 4x speed only. You can find great prices on these cards here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1069609639&name=AGP+4X%2f8X
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Agp 8x vs agp 4x
the 4x card WILL work in an 8x slot but it will only run at 4x speed because of the card limitation. also, the 8x card WILL work in a 4x slot but it will only run at 4x speed because of the slot limitation. i've done it. peace
Nov 05, 2007 | Palit Microsystems GeForce FX5500, (256...
3Dlabs Oxygen GVX210, (64 MB) Graphic Card Logo
109 people viewed this question
Top 3Dlabs Computers & Internet Experts
David Payne
David Payne
Are you a 3Dlabs Computer and Internet Expert? Answer questions, earn points and help others
