Question about Jenn-Air JMV8166BAS Microwave Oven
Microwave is stuck in convection mode. Can't get it back to microwave mode.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave convection heat shuts down
That could be several things, but to me the most likely is that your thermistor is caked with grease - somewhat shorted as opposed to open. By contrast, when the thermistor is open, the classic symptom is that the coolling fan runs more than it should. The other most likely possibilities include the damper motor or switch or control panel. You should be able to get any needed parts at Tritronics at http://www.wehaveparts.com You can find critical safety & disassembly info in the serice manual or at our Web site. We have the actual service manual for that model on our site at http://www.microwavedisplay.com/R930AKAW.pdf (if that URL fails try http://207.234.249.73/mwd/R930AKAW.pdf) Post back if you wish.
Posted on Dec 24, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
  • 6 Answers
SOURCE: microwave turntable won't turn
You will have to take it out and then take off the outer cover to expose the drive system for the turntable unless the items turns with the turntable removed. If it does then (and if it is belt driven) the belt may be worn and slipping. Anyway you look at it the cover has to come off to see what is happening.
Posted on Feb 16, 2008
  • 25 Answers
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
Posted on Jan 14, 2009
  • 1214 Answers
SOURCE: How to operate Electrolux Microwave oven Model EC9055?
Here's the manual -
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0708331.pdf
Posted on Jan 24, 2009
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Velos Microwave turntable works, product heats but does not vent
can you give me more information what is it not doing
come back to me
Aug 18, 2009 | Whirlpool GH5176XPS Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
Stck in locked mode
Try holding down the clear button for 3-5 seconds
Mar 14, 2008 | GE Advantium 120 Convection/Microwave Oven
Jenn-Air JMV8166BAS Microwave Oven Logo
24 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
