Hello, Welcome to FixYa.
While I don`t have diagram or illustration I can give some insight because this is actually very common.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the spring ( except yours is likey broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 740040 @ repairclinic ) and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
