On new Windows 7 computer, cannot complete installation of HP laserjet 2035. On installation progress indicator, current progress lists "Service: Sprint Spooler". On Overall Progress indicator, it lists "Installing Advanced TCP/IP Port Monitor." I have tried to install at least 10 times. Have swapped out USB cables, checked connects, etc.
  • 4,281 Answers
First go to start menu->control panel->add remove programs then uninstall hp printer driver from there. Click on below link. Click here Select win7 and download driver . If you connect printer with usb cable then when it ask for select installation type select usb cable .If you use ethernet lan cable means if you use network printer facility then choose tcp ip. Make sure your printer ip address is in the range of your lan network. You can set printer ip in printer menu->network settings. Install driver then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 06, 2010
HP Printer Software hangs during install CM2320series-win7-full-solution-AM-EMEA1-v3.1 HP Color Laserjet CM2320nf MFP Saturday 09 November 2013 - 06:09 PM ( Local Time CET , GMT / UTC + 02:00 )...
On my HP i discovered that where i was plugging in the usb at the back wasn't a usb port. Look at the back carefully to see that it is the right port.
Nov 09, 2013 | Office Equipment & Supplies
Printer driver
I came across this type of problem when windows 7 first came out. At that time there were no available drivers for this printer and the solution was to get a new one. Technology evolved shortly after and I saved this solution in case.
LaserJet model specific printer drivers are currently available within the Windows 7 operating system. Installation of these drivers can be performed via Devices and Printers , formerly known as the Add Printer Wizard. If the model specific driver that you are looking for does not appear in the list of available printers, clicking the Windows Update button underneath the list of available printers may provide additional drivers to choose from. Requires opt-in to Microsoft Windows Update and internet connection. In windows update select 300 DPI printing as that is all the 4L supports. Hope this helps.
Dec 12, 2011 | HP LaserJet 4L Printer
I up graded my pc to windows 7 ultimate. i have a Hp laserjet 3015 and cannot seem to make the scanner work
Chances are the printer didn't come with drivers for Windows 7.
If you have Windows 7 Ultimate x32/86, click here.
If you have Windows 7 Ultimate x64, click here.
Install the appropriate driver on your computer and it should work. Best of luck!
Jul 19, 2011 | Computers & Internet
HP-1110 printer scanner can't be use in Windows 7 PC
Follow these steps to remove previous HP drivers, and then install the new driver.Step one: Remove previous HP drivers Follow these steps to remove the current drivers.
  1. Disconnect the USB cable from the HP product, if it is connected.
  2. Click the Windows icon (c01367376.gif ), and then click Devices and printers .
  3. Find the printer icon (c01813941.gif ) representing your HP product, right-click it, and then click Remove device .
  4. Follow the on-screen instructions to remove the driver.
  5. Repeat these steps to delete multiple instances of the same printer icon, and also for any fax icons for the product.
  6. Reboot your computer.
When your new operating system is up and running, simply connect the USB cable from the computer to the back of the HP product, and then press the Power button (c01602202.gif ) to turn it on.
Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
Feb 28, 2011 | HP LaserJet 1000 Printer
My pc is not seeing my printer. i'm using laserjet 1100, and using windows 7. i have installed the driver, but still no progress. thanks in anticipation. Akpoviri Paul, Nigeria.
There is no sign of hp laser jet 1100 printer in my pc which mean the programe of hplaser jet 1100 is downloaded in my computer or could be any other prob
Feb 03, 2011 | HP LaserJet 1100 Printer
HP 1010 Laserjet drivers in windows 7 support
try going to the hp web site and downloading the correct driver for the printer
when finished , right click on the printer , click on the compatibility tab and tick box , highlight win 7, apply and ok
Apr 04, 2017 | HP Computers & Internet
Can't get my old hp laserjet 1000 series printer to work with my.
The original solution was to "download the Windows Vista drivers. These drivers will work with Windows 7".
There are Windows 7 drivers available now, so here is the link.
There are two different sets. One for 32bit Windows 7 and 64bit Windows 7.
To determine which version of Windows 7 you have:
Find the Computer menu item in the start menu by clicking on the Flag button in the lower left corner.
Right click on "Computer" and select properties from the list in the contents menu.
You will see under the System section a mention of the System type.57de736.jpg
Download the matching driver.
Thank you for using FixYa.
May 03, 2010 | HP LaserJet 1000 Printer
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
Only prints in black. Windows 7 driver update
Print a 'Configuration Page' from the printers <Information Menu>
Press the green tick button to enter the menus, and use the <, > arrows to scroll thru menus.
Then press the green tick button to select...
If, as I suspect, your Configuration Page is in colour, and looking ok - the the problem is in your computer - Printer Driver setup, or Windows......
Like all the others
Have fun.
Dec 21, 2009 | HP LaserJet 2605DTN Color Printer
I need a simple download for my HP Laserjet 6L
Windows 7 print driver available
LaserJet model specific printer drivers are currently available within the Windows 7 operating system. Installation of these drivers can be performed via Devices and Printers , formerly known as the Add Printer Wizard . NOTE: If the model specific driver that you are looking for does not appear in the list of available printers, clicking the Windows Update button underneath the list of available printers may provide additional drivers to choose from. Requires opt-in to Microsoft Windows Update and internet connection.
Nov 29, 2009 | HP LaserJet 6L Printer
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
