If you have a little bit of knowledge mechanically you can unplug the dryer and pull the top off by removing the 3 screws across the back at the very top, slide it back and lift it off. Inside of the dryer, at least in mine, there was a plastic folder on the inside with tech instructions that list the fault codes and it also tells you how to run a diagnostics mode on your dryer. Hopefully this will help you at least determine if it is something you need to call a tech to fix.
