Question about Texas Instruments TI-Nspire Graphic Calculator
I downloaded the new OS and it reloaded and it never turned back on. it just stays on the loading screen.
    Problem Solver:
  • 14 Answers
First of all erase your operating system. Then, find and install operating system 2.0 first. Once you do that, you can download and install the latest operating system onto your calculator. It should finish the loading screen.
Posted on Aug 20, 2010
My Sylvania netbook says loading os image and stays right there
There are a few things you can try to fix this issue. The first thing is called a hard reset. Remove the battery and unplug the netbook from power. Press the power button for 30 seconds and then release. Replace the battery and plug the netbook back in. Try turning the computer on again and see if the same message displays. If it does, remove the battery and unplug the power, remove the memory chips from the computer and then reseat them. Replace the battery and the power plug and turn the computer back on. If it is still hovering with that message, you may have a crashed hard drive and will need to replace it and reload the operating system back on it. The only other thing you can do is do a full system restore with either the OS disks that came with the machine, or if the OS came preloaded on the netbook, there is usually a hidden partition that can be accessed to try and reload the operating system back to the way it was when it was new. In any case, you may or may not have lost whatever info you have on the drive unless you backed up your data somewhere along the line. Depending on where you are located, many of us are licensed, certified technicians that can help you out to determine for sure what is wrong.
Jan 09, 2015 | Sylvania Computers & Internet
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Bb 8310 has white screen and error 523 message on it
Thank you for using fixYa
There is a problem with the phone OS
the most efficient fix would be to reload your OS
If possible do a back up of your phone and then reload the OS
here is a link with information on how to load the OS
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
Hope the information is helpful
Jul 14, 2011 | RIM BlackBerry Curve 8310 Smartphone
I need help with my Blackberry Bold 9000. I made a wrong input with my password and now my device says reload software: 513. What do i do to correct this and make my Device work perfectly again ?
Dear customer
You need software flash for your handset.If u are not a Technician then its better to go ur nearest Blackberry customer care.If u are satisfyd by my information then please vote me .Thank you for visit.
May 24, 2010 | RIM BlackBerry Storm 9530 Smartphone
It wont load or turn on
Dear Brother, You will need to reload the OS onto the device.............. OS software Get From Here(India); AT&t Click here ; Or CLICK here Once downloaded and installed, follow these directions:
  • Download the OS file from your carrier website to the PC then install it to the PC by running (double clicking) the file you downloaded.
  • Go to c:program filescommon files esearch in motionapploader directory.
  • Plug in BB and double click on "Loader.exe." It's located in the same place as the above vendor.xml file.
  • The process takes about 45 minutes to an hour depending on how much data you have to backup and restore during the process. Once it's done loading the new OS it will reboot (it may do this twice during the entire process.) You will see a white screen with an hourglass for up to 20 minutes at a time while the DM says "waiting for initialization." If, for some reason, you end up with a white screen with small icons and the number 507, simply connect to the PC again and run Loader.exe again and it should load the OS to the device.
I like to get Feedback...... Hope THIS HELPED YOU............... Thanks For Using FixYa.............
Apr 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
Computer wont start
IF you are using vista os means the best way is reload the operating system. if you want to tack your data without loosing then you download puppy linux bootable cd from net it is free. using this u can taka your whole data. this os it takes the time to load just 2 mint.
Mar 17, 2009 | E-Machines C3060 PC Desktop
Dunno what happen??
When You Boot up your screen goes in to the windows xp loading bar and after a quick blue flashin screen pops up and it restarts unfortunately this is what they call the Blue Screen of Death so more than likely you harddrive with the os is corrupted so either you will need to reload the OS or by a new harddrive and load the Os on that Harddrive
Jan 22, 2009 | Microsoft Windows XP Professional
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Compaq presario c700 not working
boot your system in safe mode by pressing f8 during the booting process, if it boots then restore your system to back date whete its working fine, if it does'nt boot, there might be the visus problem, or os corruption, reload the os
Oct 20, 2008 | Compaq Presario 700 470024-192 Notebook
Acer aspire 5715z/5315, turned laptop on took time to load up wasnt responding,restarded laptop then it wouldnt restart then i turned it of manually, turned it back on,screen acer back ground in the bottom...
Reboot your system-press and hold F8 until you get a list of options-select Safe Mode-enter.Your system will run in Safe Mode,giving you a dropdown list as it progresses-check where it stops.In this way you can establish wether you have a corrupted or incompatible driver and which {Graphic ie} stop the system.You will have to reload the OS to solve the problem.If you cannot even boot into Safe Mode,your drive very likely crashed.Happy landing.
Jul 22, 2008 | Acer Computers & Internet
Texas Instruments TI-Nspire Graphic Calculator Logo
166 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
