Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock is on. Will not operate - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
I had my passenger headlight bulb replaced. Now when I go to start my 2009 buick lacrosse, my horn honks, wipers come on, trunk pops open and loud bass static on my radio.
Who replaced the headlamp bulb ? Take it back . Everything your having problems with are all controlled by the BCM - body control module . May have crossed wire's ,shorted etc....
This vehicles BCM functions as the Power Mode Master (PMM). Refer to Power Mode Description and Operation for a complete description of the power mode functions.
Body Control Module
The various body control module (BCM) input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The BCM functions include the following:
• Battery rundown protection--Inadvertent power--Refer to Interior Lighting Systems Description and Operation .
• BTSI/automatic transmission shift lock control--Refer to Automatic Transmission Shift Lock Control Description and Operation .
• Bulb check--Refer to Instrument Cluster Description and Operation .
• Chimes--Refer to Audible Warnings Description and Operation .
- Check gages
- Content theft deterrent
- Door ajar warning
- Headlamps ON
- Key-in-ignition
- Oil reset
- Park brake warning
- Seat belt not fastened
- Turn signal ON
- Vehicle theft deterrent
• Door lock interface--Refer to Power Door Locks Description and Operation .
• Exterior and interior lighting control--Refer to Exterior Lighting Systems Description and Operation .
- Automatic lighting control
- Backup lamps
- Daytime running lights (DRL)
- Fog lamps
- High/low beam head lamps
- Park brake lights
- Turn hazard lamps
• Gage control--Refer to Instrument Cluster Description and Operation .
• Heated seats--Refer to Heated Seats Description and Operation .
• Horn interface--Refer to Horns System Description and Operation .
• Instrument cluster indicator control--Refer to Instrument Cluster Description and Operation .
• Interior lighting--Refer to Interior Lighting Systems Description and Operation .
• Key-in-ignition sensing--Refer to Audible Warnings Description and Operation .
• Parking brake state sensing--Refer to Brake Warning System Description and Operation .
• Retained accessory power (RAP)--Refer to Retained Accessory Power (RAP) Description and Operation .
• Rear compartment interface--Refer to Power Door Locks Description and Operation .
• Rear defogger--Refer to Rear Window Defogger Description and Operation .
• Remote function control--Refer to Keyless Entry System Description and Operation .
• RFA communication link--Refer to Keyless Entry System Description and Operation .
• Seat belt use sensing--Refer to Seat Belt System Description and Operation .
• Theft deterrent vehicle/content--Refer to Content Theft Deterrent (CTD) Description and Operation or Immobilizer Description and Operation .
• Washer solvent level sensing--Refer to Wiper/Washer System Description and Operation .
• Wiper/washer--Refer to Wiper/Washer System Description and Operation .
May 07, 2018 | Buick Cars & Trucks
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
Why won't the passenger door unlock?
An automatic door lock or unlock actuation
A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation.
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K?© resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
I'll post a youtube video on how to test the power door locks computer controlled , check it out ! Your problem could be a switch or the lock actuator , BCM , wiring etc.... you need to test it to see !
I'll
How to test computer controlled door locks
Mar 22, 2014 | 2008 Saturn Aura
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have a control locked alarm on a whirlpool duet washer??
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ABS Light comes on, speedometer stops working and locks switch
I will bet the check engine light comes on as well?
Jul 05, 2017 | 2003 GMC Yukon XL
2002 Jeep Grand Cherokee electric door locks not operatin
the passenger door switch pack controls all door locks as this is the receiver from the remote you might want to try this and also check connections
Jun 07, 2009 | 2004 Jeep Grand Cherokee
Whirlpool Duet GHW9150P Front Load Washer Logo
139 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
