Question about SanDisk Sansa e250 MP3 Player
I cannot add songs on my sansa
The computer cannot detect my sansa=( i cannot add songs.when i plug my sansa to my computer.mtp device appears.but icannot see the hardware on my computer
OH MY GOD Computerrep!! You damn rock!!! I've been trying to solve my problem for hours!! I was plugging my Sansa e250 to my USB hub and windows wouldn't recognize it... And now I plugged it directly to the back of my laptop and it works perfectly fine!!! YOoooohoooo!!! Thanks dude!!!!
Posted on May 09, 2009
  • 758 Answers
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..that is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Apr 28, 2008
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Oct 28, 2008 | SanDisk Sansa c200 MP3 Player
Sansa m240 computer connection cuts off in MTP mode with device cannot start error message in the device manager
Uninstall all Sansa software using the add/remove programs function, and then reinstall it.
Sep 22, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Sansa M250 Rhapsody Problem
Unfortunately you are not going to be able to go online to sync your device...All music subscription such as napster and rhapsody require you to sync your device every single month using their actual software..The reason is to prevent customer from cancelling their music subscription..once you cancel your membership all the songs you have on your device will become useless.In another word, you are renting the music from the subscription company...
P.S.Please rate accordingly...
Thank You
Computerrep
Apr 21, 2008 | SanDisk Sansa e250 MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Cant tranfer songs
you need to try a bunch of things to try to figure out whats wrong. you can try
different computers
different usb ports
how the device appears in device manager
changing modes on the player itself
Feb 05, 2008 | SanDisk Sansa e200 MP3 Player
Synchronize to continue your music subscription
first you must format the player using msc mode then after that retransfer the songs to the player. If you are receiving this message it means that the songs on the player have expired. This is normal if you download the songs off rhapsody, napster or any online music stores and if you have ripped songs iwht copy protect music on it if you ripped them using windows media player 10.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
I can't remove songs with WMP
You have to first change the USB mode on the player to MTP (as opposed to MSC). Forget using the Windows Media Player (yeah, I know). Go to Explorer, go to drive E or whatever your Sansa is listed as....open it and it will show different types of folders. Go to MUSIC folder. The songs are listed and you can delete, e.g. delete mp3 and keep WMA of the same song, or whatever else you want to delete.
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
