Question about Weber Genesis Silver B Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the food?
    Problem Solver:
  • 9 Answers
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Posted on Aug 12, 2010
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
The users manual arrived with the product but there are no user instructions and aswell as direct grilling I want to use the grill to cook joints etc. What setting do you use for indirect grilling and Is...
Direct Grilling is putting the items you're grilling directly over the burner(s) . Indirect Grilling is preheating the grill, turning off one or two burners and place the food over the burners that are OFF. In direct grilling requires cooking with the lid closed.
For more info on using a gas grill, as well as recipes got to the following link.
http://www.barbecuen.com/begin-gs.htm#axzz1SkGNJ9p8
Happy Grilling!!
Jul 21, 2011 | Ducane Affinity 3100
How do we fix a gas grill that doesn't cook evenly
Usually if you're have hot and cold spots, it's the burners that need to be removed and thoroughly cleaned. In addition, cleaning the venturi valves while the burners are out, is equally important. The Venturi valves are part of each burner. You will see them near the open end of the burner (looks like 2 slots cut into each side of the burner) where it fits over the burner orifice. While the burners are out, closely inspect each one for corrosion or rust thru. If you find severe corrosion or rust thru, the burner(s) should be replaced.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 04, 2011 | Weber 3820301 Gas Grill
Where can i buy the fitting (converting kit)for weber e 310 ng to lg
Sorry, but there are no conversion kits available for Weber Grills. They were no designed, tested or approved to be converted from one gas type to another.
For confirmation of the this, see FAQ link to Weber, below.
http://help.weber.com/faqs.aspx
Apr 17, 2011 | Weber Spirit? E-310 Propane Grill
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
I have a beef eater signature series 3 burner please advise instuctions for roasting pork
Depends on what your cooking.A roast of pork,I would brine for 3-6 hrs before hand,then use 2 burners for indirect.To get a better idea try one of these sites.Your making me hungry thinking of this :}
{I do a pork tenderloin in the smoker bacon wrapped,butterflied with stuffing,smoked with apple wood}
http://cookeatshare.com/popular/cooking-a-pork-roast-on-a-gas-grill
or
http://www.foodreference.com/html/rubbed-g-pl.html
Good Luck,hope it turns out well.
Dec 24, 2010 | Beefeater Signature S3000e 3 Burner
Gas smell when in use only.
you have a gas leak could be spilt burners needs to be fixed or new grill
May 10, 2010 | Weber Q Grill
My Weber gas grill is less than a year old. The
gas regulator make sure all burners are off when you connect bottle... the units have a leak sensor and will stop the gas coming out because it thinks you have a leak when you connected the bottle. now try hooking up the bottle again with all the burners closed incl. the side burner and the infa red. It will work o.k. then
Apr 07, 2010 | Weber 3820301 Gas Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Weber Genesis Silver B Grill Logo
296 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
