Question about RTO Oar Sockets
Wiring digram 25 hp evinrude 1985 - RTO Oar Sockets
Looking for a wiring diagram for a 1985 85 hp evenrude
http://shop.evinrude.com/category/342499/Literature
try this web site. since I do not have enough info, maybe you can find what you are looking for on this site. Good Luck.
Aug 05, 2017 | HP Boating
How do I tell what model year my 85 Evenrude starflite motor is if I cant find a compliance plate ???
go google and type in-- evinrude outboard 1985 ( you have to put the hp in ) and there are sites that will help the model of the engine
take what ever information you have on the engine ( year , make , hp sales name etc) to an evinrude service center and have it identified that way
Oct 02, 2016 | Boating
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Where can I find a wiring diagram for 1970 25 hp Evinrude 25003C?
BUY A 1970 25 hp Evinrude 25003C? MANUEL
Sep 19, 2015 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Evinrude 40hp outboard
usually in the head. Check a parts book.
Jul 11, 2014 | Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
RTO Oar Sockets Logo
59 people viewed this question
Top RTO Boating Experts
merc racing
Level 1 Expert
Mike
ffstaffsta
ffstaffsta
Are you a RTO Boating Expert? Answer questions, earn points and help others
