My gorenje washing machine keeps flashing up error code "F02", any help please
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
taran_2005
  • 10515 Answers
SOURCE: CDA C1930, F02 APPEARS
If the F/02 error shows, it indicates a "long drain"; If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press the PAUSE/CANCEL button twice to clear the display and verify the following:
  • Verify that the drain hose is not plugged or kinked.
  • Verify that the electrical connections at the pump are good and make sure the pump is running.
  • Verify that the drain pump filter has not collected any foreign objects.
If none of the above corrects the problem, unfortunately you will need to replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 22, 2009
SOURCE: Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
Posted on Jun 01, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It is FO 2 its happpend twice no papper work for it?
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
Mar 28, 2011 | Washing Machines
The F02 keeps flashing M#110.42832 CSM#1004028 pls help
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 09, 2011 | Kenmore HE3T Washer
My whirl pool sports washing machine is displaying the error code F2? pls suggest some remedy
HI There
i have this code for you and this is helpful and let me know how it goes.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pumpThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Whirlpool Washing Machines
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I keep getting an error code that flashes F02
"F02" is a Long Drain error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The majority of the time, all you have to do to correct this problem is to clean out the drain pump reservoir or drain hoses. Follow the advice in the link provided. If all preliminary checks do not solve your problem, the manufacturer recommends replacing the drain pump. If you have questions, please let me know. I hope this helps you.
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
Potential Causes
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not work flashes error code f02
If this is a Kenmore or Whirlpool model, an "F02" error code indicates a "Long Drain" problem. This means you need to inspect your drain line and or pump to ensure there is nothing obstructing the drain. Can you please post back to confirm correct Manufacturer and Model number?
Mar 25, 2008 | Washing Machines
Washing Machines Logo
1,524 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
