TV manuals Hi, I'm having trouble setting up my set top box with my TV as I don't have a manual for the TV. Can you help?
  • wstanleyca Aug 30, 2008
    need manual for f27677bc tv
  • Anonymous Sep 06, 2008
    need User or Operator manual for Mitsubishi CS-36509
I need a manual for a Zenith TV, Model number: SY2053S.
Posted on May 04, 2008
  • 8,617 Answers
Please post the model number of your TV and I should be able to locate a manual for you.
Posted on Apr 27, 2008
I have a TH-50PY700H TV linked to an M8S KitKat 4.4.2 Kodi TV Box but the top & bottom of the display is cut off. Can anyone help pls.
If the signal is a product of the ott box than go to settings and find display. It will tell you how to make screen size to fit your screen.
Aug 19, 2017 | TV Box Televison & Video
With set up box audio in to tv causes high pitch sound
I am assuming this should read 'Set top box'. What kind of cable are you using?
Usually the set top box connects via a SCART lead but yours may be HDMI if it is a very new set top box.
If you are using RCA plugs, you may have cross connected the wrong cables. The RCA cables should be colour-coded. RED and WHITE are for audio, Yellow is for video.
Best advice is to switch it all off, remove all the cables you attached, and start again. The instruction manual/user guide usually has an illustration to help you identify what your set up looks like - there are usually several examples.
If the cables you need did not come with the set top box, you will need to purchase them.
When you are connecting audio leads, you should use the 'audio out' on the set top box and the 'audio in' on your TV set.
It would help to know the EXACT model number of LG screen you have and the make and EXACT model number of the set top box.
Good luck.
Mar 07, 2015 | LG 42LC2D 42 in. LCD HDTV
Samsung Smart TV Universal Remote setup with sudden link
We need to know the model numbers of the television and the set top box and the remote.
Nov 24, 2013 | Samsung Televison & Video
Philips pronto remote problems
Refer the user manual to your set-top box for details.
Jul 16, 2013 | Philips Televison & Video
How can I set the tv channel on cinco flat screen television. I lost my manual so television setting is currently in Cable channel. please help me
Hi. Just set the TV to CH 3 or 4. These are the channels the TV will run on the set top box (cable box) or (dish network) If you have HDMI cable to connect to your TV. You need to go to menu and settings Video 1 or video2 or you can use component 1 or 2. or maybe AUG. Good luck.
Sep 26, 2011 | Televison & Video
We were given this tv and don't know if its digital or analogue, will we need a set top box?
This tv is capable of both digital and analog settings. It is however recommended for use with digital components. You can reference the manual at This should be a helpful reference with setting up your newly aquired NEC PlasmaSync. Have fun with it!
Jun 10, 2011 | NEC PlasmaSync 42MP1 42 in. Television
Our tv audio is making white noise on all the channels
If you are connected your tv with a set top box, check the set top boxes' connection,and its settings according with it user manual. If the system set has varied to an other, this type of trouble will occur. If your are cabled, check the system adjustment of your Tv, and it is best to make it auto. Go through its manual and refer to the sound adjustments, and set the system to auto' If you have this option on remote control, "system Button", press it repeatedely to get the system set to auto. OK.
Dec 21, 2010 | Sanyo DS25390 TV
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
