Question about GE 20 Amp 1 In Double Pole Circuit Breaker THQP220
Double 20 breaker switch slot in the back is to short and it won't seat right.
  • 760 Answers
Are you installing it in a GE panel? Look on panel cover and it will list the compatable breakers. Even though some breakers "fit" different brand panels, they ar not approved if not listed by manufacturer of the panel to be used in that panel
Posted on Aug 11, 2010
  • Tom W Aug 11, 2010
    Oh, I didn't notice the exact number. If this is a 1/2 size breaker there are two facts. 1-It installs between spaces (connecting to two poles on the bus) 2- The panel only alllows certain spaces to accept these breakers. You will notice a small vertical tab on bussbar for it to plug onto. Problem wih these is you'll leave 1/2 space vacant above and below breaker unless you have some 1/2 size single pole too. Prior to 2008 a panel could only hold 42 ckts.
Power interrupted during cycle. now it won't do anything. I think it needs a reset. checked fuse box, it was fine.
As a general rule, what you are describing happens if the power is interrupted for a short time and the machine doesn't get a chance to do a reset before the power comes back. There is a good chance if you power the unit off then actually unplug it from the wall and leave it 20 minutes it should do a reset and be OK. REcognising this is a built in, I would hope there is an isolator switch somewhere nearby you can flick, but if not you will have to switch the breaker that feeds the kitchen in your breaker box.
Jul 04, 2011 | KitchenAid KUDM24SE Built-in Dishwasher
Can a 240 volt outlet be ran off this breaker and can a 240 volt electric baseboard heater be wired to it or should i use double pole breaker?
You need 240 breaker:
Notice that your 240V breaker is twice as wide as regular 120V breaker.
Notice that both switches are tied together on 240V breaker, making this a double-pole breaker.
For more information about breakers and 120-240V circuits:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light 15 5 Wiper/washer 15 6 Fresh air blower 16-valve only: Air conditioning 20 7 Taillights, side marker light, right 10 8 Taillights, side marker light, left 0 9 Rear window defogger 20 10 2.0 16-valve only: Fog lights 15 11 Headlight, high beam, left,High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn 16-valve only: Radiator cooling fan 10 14 Back-up lights, washer nozzle heaters 10 15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, 16-valve only: Multi function indicator 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15 22 Radio, cigarette lighter 10
Relays Relay No. Description 1 Air conditioning 2 Open 3 Digifant control unit 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Rear Wiper 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or power seat circuit breaker 19 Automatic transmission 20 Open 21 Power window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Power window fuse
Nov 17, 2010 | 1993 Volkswagen Passat
Power windows stopped working
If ALL the windows quit working, then it's either a bad circuit breaker or a short circuit. There are two fuse/relay/breaker panels: under the hood and under the back seat cushion. The power window circuit breaker is under the back seat cushion, near the battery. Remove the back seat completely, then remove the fuse panel top and inner cover. The fuse diagram is inside the top cover. Circuit breaker # 57 is the one. Pull it out. Use your voltmeter/multi-tester to check for continuity through the breaker. If there's no continuity, the breaker is bad and needs to be replaced. If it's good, then you have a dead short somewhere that causes the self-resetting breaker to uncouple when you attempt to operate a window. If so, the short will need to be traced down and repaired. Good luck.
Jun 27, 2010 | 2000 Buick LeSabre
Federal Pacific Breaker and whirlpool appliances
You have the wrong breaker You need to buy a breaker that pulls power on each side of the bus if it is not a single pole double trow switch it will not work on the box. It needs to get power from both buss bars. Go to a electrical warehouse to get the right one.
Jan 04, 2010 | Kitchen Ranges
Compressor causes 20 amp breaker to trip.
If I did the math correctly, 5.5 HP is right at the boarderline of 20 amps, particularly for an older machine that has some deteriorating electronics.
What to do? Can you reconfig the motor to run on 220 Volts??? It would then run on 1/2 the amps.
If you have a dedicated 120 line for this compressor now ... all you have to do to change that to 220 is change the breaker (I presume you have a vacant slot to do this). Find the "neutral" for that wire (white) ane make it the "red" for your compressor line ... (and mark it as such for your future behefit) change the outlet from 110 V 20 A to 220 V 20 A. Both lines will run on #12 with G wire.
If you dont have a slot, you could change one of your standard slots to a "piggy back" remodeling style breaker (has two breakers in one slot). This will free up one slot in your panel for the new 220 (double pole) breaker.
Let me know what you think
Thanks for using FixYa.com
Positive comments appreciated
a
Oct 29, 2009 | Air Tools & Compressors
I own a YS 4500 Craftsman tractor (Model No. 917 287 242). It was running fine the last time I used it but then wouldn't start. No response when turning key. I checked battery with multimeter - it's fine....
If you think it is the seat switch you can check it with your multimeter, just unplug it and check the resistance across the switch with and without pressure on the seat where the switch is located. Another way to test would be to take a short jumper wire, unplug the switch and jump across the 2 wires in the plug, then try to start it.
I would be more inclined to think it is the fuse in your system, however. Most of the time the fuse is a plug in fuse located on the right side of the tractor, behind the back of the engine and is usually a blue (15 amp) or yellow (20 Amp)
Oct 05, 2009 | Garden
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
GE 20 Amp 1 In Double Pole Circuit Breaker THQP220 Logo
212 people viewed this question
Top GE Electrical Supplies Experts
Steve
Lawrence Oravetz
robert
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
