Question about Dometic RM2652 Refrigerator
My Model RM2852 Refer will not change from electric to gas. It tries. The igniter is working and gas appears to be on for about 30 seconds and then kicks off and stays off. Inside the "Auto" light is on but after about the same 30 seconds the "Check light comes on and stays on. Any ideas on what to replace? I am 1500 miles from home. Thanks for any suggestions.
  • ontheroad48 Aug 06, 2010
    I really need assistance NOW, not next week.
  • 24 Answers
The same thing happend to me, Try changing the thermocoupler. it's a probe that is mounted just above the flame or get the coupler tested. this part only cost me $23.00 easy to change.But if not it might be the lower circuit board.
Posted on Aug 11, 2010
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
I got a RM 2852 IN A 5TH WHEEL. It will work fine on gas,but 110v does not work,Any suggestions? Thanks,David
We were told that its a faulty control board on most Rm2852 units. a factory defect.
Ours did the same thing first the gas would not stay on to cool but the unti worked fine on electric...now the electric is not working...the heater gets hot and burner comes on but does not stay on..they system shuts down..and will not cool. .
Jan 29, 2011 | Dometic RM2852 Refrigerator
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
RM2852 has never worked on electric.
there a 3 electrical parts
1) the switch
2) the thermostat
3) the heater element
You will need to test for fault , but most likley is the element
Aug 16, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic rm2852 does not run on gas
Sounds like your ignitor porcelain is cracked. Yes there is a miliamp signal sent to the circuit board to stop the ingnitor from arcing
Dec 30, 2008 | Dometic RM2852 Refrigerator
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Dometic RM2652 Refrigerator Logo
189 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
