Question about Pyramat Sound Rocker Gaming Chair
As soon as i plug in the wire to turn it on, it makes an unusual sound.
I have the same issue, its something to do with the power. I have never found a solution.
Posted on Aug 07, 2010
I have s176w jennair range that flashes and F1 signal and a makes a buzzing sound when I turn any burners on
F1 usually go back to the electronic control board. Unplug and replug the power back on. If error code comes back, replace board.
You might want to check all wires going to the board for anything unusual...make sure they are properly attached etc.
Oct 23, 2013 | Jenn-Air Kitchen Ranges
My Marshall mg100dfx has just recently began to schreech and buzz as soon as I power it on. No instrument plugged in. No previous buzzing or unusual sounds. Now all of a sudden when I hit the power switch...
It sounds like a bad capacitor in the item, the value changes as it warms up. I would suggest pre-warm up before the public arrives because this may take time to find the problem, and then you can tackle it or bring it to a technician.
Jun 01, 2012 | Audio Players & Recorders
HP Pavilion tx2000 monitor not display, all the light on execpt the monitor blank
Sounds like your display has completely gone out. If your device is under warranty, you should try to contact HP as soon as possible and request that your device be repaired.
You could try swiveling the display around or tilting the laptop at unusual angles--if there's a loose wire or connection, the display might flicker on.
Mar 01, 2011 | HP Computers & Internet
Not turn on only clik
Goodday! what do you mean...! its not turn on when you clik it.? .......1st chek the power supply if its ok and plug...if ok then....try to clik it or press it more. check the push botton if not yet damage if not.! check the supply voltage if not yet working...if theres is a voltages....check for unusual sound or smell for burn chip or parts.if there is...? need for repair.......................in the speaker...! check the wiring if not cut or damage....check also the proper wiring or installation of your speaker maybe its not properly connect or wrong connections...! thank you..
Feb 13, 2011 | Car Audio & Video
My punch 250 a2 powers up but no sound is produced only static if i wiggle the speaker wire
um sounds like there is no sound input, if you are running rcas ensure they are plugged in and the radio and headunit, and check for a cut in the cable, this is very unusual not to have any power output at all, triple check your headunit outputs, and your amplifier inputs, make sure you arent crossed anywhere. hope this helps
Aug 08, 2010 | Rockford Fosgate Punch 250a2 Car Audio...
My service engine soon light came on so i hook it up and the camshaft position sensor code came on so i bout the sensor from autozone and replaced it and the same light for the same code still comes on...
It sounds like a bad plug or the wire is damaged, do a continuity test on the wires to make sure there is not excessive resistance in one of the wires
Jul 03, 2009 | 2001 Cadillac DeVille
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
What is the meaning of 3 long beep of Soltek mainboard?
Try the following. If you are comfortable inside the machine.
Discharge static by touching the metal of the computer case
2.) Unplug and reseat all cards in system Video Sound etc.
3.) reseat ram chips in slots
You should be good after this.
Jan 20, 2009 | Computers & Internet
Humming?
Make sure sound is comming from ur hard-drive.If it show possible reasons can be.... 1. Your hard-drive is not screw-up proerly. It is unbalanced. 2. Take care you hard-disk safely it may cresh soon.For long age of your hard-disk shut down your pc properly.
Sep 10, 2007 | Toshiba Portege M205-S810 Tablet PC
Pyramat Sound Rocker Gaming Chair  Logo
101 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
KoKo Lamoco
KoKo Lamoco
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
