I have a wireless g pci adapter and it is installed on a computer running windows 2000 server. It is supposed to receive the signal from the wireless router wrt54g. It does not find the signal but somehow it finds signals coming from outside the house. It doesn't connect to any of them and the taskbar says network cable unplugged. I also have a nic installed in the computer that did work via ethernet until the wireless come along. neither will work and i have tried over and over again to make it work but it wont
    Problem Solver:
  • 8 Answers
Hi, did you run the CD before you connected the adapter? I know the box says 'easy, no set-up' but there usually is a CD that needs to be run BEFORE connecting the device. If thats done, try bringing up the 'connect to a network' interface, selecting your network and click connect. If you have set up a wireless security password, enter it and click connect. The network cable unplugged is normal when you are running a wireless setup. I hope this is of some help.
Posted on Apr 27, 2008
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
Display Problem and Wireless problem with Windows 2000
The drivers for windows XP are available on this site : Drivers for Toshiba laptop
You can try and see if they are compatible with windows 2000, or install Windows XP which is better anyway.
Alex
Jan 29, 2009 | Toshiba Satellite A135-S2276 Notebook
Cant connect wirelessly
Yes u have to buy a netgear N dongle ...
Because N works on 5 ghz and G works on 2.4 Ghz
You can buy netgear WN111v3
Nov 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Need windows 2000 server nic driver
Hello sir,
Try this link for Windows 2000 server.
http://www.opendrivers.com/driver/212753/3com-etherlink-server-nic-3c985-3c985b-driver-
windows-2000-free-download.html
Best of Luck
Don't forget to rate the solution.
thanks
Mar 11, 2008 | HP Compaq d220M (829160054797) PC Desktop
WIRELESS PCI 54M G NETWORK LAN ADAPTER CARD 802.11 b/g INSTALLATION
try to unplug it all modem roughter then modem roughter computer on see if its working do repair also thx nick
Feb 05, 2008 | Computers & Internet
Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Mar 18, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
