Question about Fuji FinePix F10 Digital Camera
My shutter will only open half way when I turn it on.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 06, 2010
Cannon rebel DS6041 shutter problem
You need to determine what is preventing the shutter from opening/closing. Set to "B" mode and with the lens OFF, press shutter button but DO NOT RELEASE just yet. Not any peculiar motions (grabbing, skipping, folding etc). The curtain may well be out of alignment, or there may be a lose part which is grabbing hold of another component.
If you do find the culprit, and it can be fixed on the spot - do it. Technicians can charge >$65 just to open the thing. Then you have to wait at least a week to get it BACK!
Nov 09, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Shutter is stuck on open position
shutter is stuck half way open and when the camera is turned on it says lens error 0x001110000 and then it shuts off
Apr 30, 2009 | Cameras
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Camera shutter does not open
Call Microsoft and they will repair your Camera for free the phone number can be found here http://support.xbox.com/support/en/us/nxe/contactus.aspx
Dec 17, 2008 | Microsoft Xbox 360 Console
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Shutter opening problem
How hard did you press on the button? it will focus if not all the way. Also, check your battery. Other than that, I don't know.
Apr 08, 2008 | Fuji FinePix F11 Digital Camera
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Fuji FinePix F10 Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
