Question about Dishwashers
I have a kenmore ultra wash model that has the to spinning nozzles (1 for each tray). The top nozzle does not spin and the dishes are not getting clean in the top rack and the silverware and some of the dishes are not getting clean in the bottom rack. Can you tell me what the problem could be?
  • 4,323 Answers
Hi
Please check whether the holes of upper arms are blocked with kink or debris. Clean the holes and check for any splits or leaks in spray arm and pump cover. You may also need to clean the filter module. Please refer the instructions to clean the filter module and to service other components inside the dishwasher--
Kenmore Dishwasher Filter module cleaning
Kenmore Dishwasher Component servicing
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 06, 2010
Aquarius model dwf31. Why doesn't it clean items in top rack?
If you look at the bottom arm you will notice an extension nozzle that comes up out of the center. If you block that from going up during the wash cycle with dishes then the water will not reach the top. This is what makes the top arm spin.
Dec 24, 2015 | Hotpoint Dishwashers
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
I have a Kenmore Elite-not sure where to find the model number but the manual lists 665.160524, 1650594, 160534, 170524, etc. the problem is that the top dishes are not being washed. nothing is...
Hello. The problem is most likely in the rear of the top drawer. Pull out the drawer and empty it of all dishes. In the very rear you will see a tube that will align with the water supply tube on the rear of the machine. there are little clips that hold this tube in position. Sometimes the tube gets disconnected due to a large pot or tray on the bottom and must be reattached by merely pushing the clips onto the tray. Regards, Joe
Jan 16, 2010 | Dishwashers
I have a Kenmore Dishwasher model # 587.1523. For some reason, after washing or rinsing cycles are complete, water is still in the bottom tub. My question is, besides the troubleshotting tips in my use and...
Good Evening,
Have a Kenmore\Quiet Standard Model#587.1523 900
Dishes are not getting washed, cyles through , Believe the inside Top Nozzle is not getting any water up the tub to the top of the washer ?? Not sure hoo to fix this ?
Thank YOU for Your Time.
Mrs. Garza
Jan 13, 2010 | Kenmore Dishwashers
No water going thru washer arms
Check to see if the top rack wash arm water fitting is mating with the outlet on the back inside of the machine and the spinning was arm. This fitting can become displaced causing the water from the pump to just spray out into the washer and not clean the dishes on the top rack. it's usually just a matter of re-positioning the fitting and making sure it's connected to the top rack spinning wash manifold.
Apr 27, 2009 | Dishwashers
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
