Question about HP LaserJet M3035xs MFP All-In-One Printer
My fax confirmation sheet says communication error 38.
4 Suggested Answers
SOURCE: Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Posted on Apr 16, 2008
Joed911
  • 4338 Answers
SOURCE: Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 14, 2008
Joed911
  • 4338 Answers
SOURCE: Canon ImageClass MF6590
Press the plus or minus sign to get to the "Report Settings" then press ok.
Under report settings select "TX Reports"
then set "Output" to YES
under that set "report with TX image" to ON
This will give you a confirmation with the image of you fax. Here is the manual, info on pg. 251
http://gdlp01.cwss.com/gds/0300000953/MF6500_BASIC_en_us_R.pdf
Thanks, Joe
Posted on Dec 11, 2008
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
When i send a Fax how do i get a copy that the fax was Recived to the person i sent it to
You will get sound signal like longer beep. when you get three short beeps it means error (sent fax was not successful).
Also you can set XMIT report (means after every your sent fax, you will get printed out sheet with confirmation or error for previous sent fax - not recommended, will increase consumption of paper and toner).
If want to, follow steps:
- press key "Menu/Set"
- press "2" key
- press "4" key
- press "1" key (will see "trans: off")
- with navigation key "down" or "up" select "trans: on" or "trans: on + image"
- then press key "Menu/Set" to confirm it
Done
Feb 02, 2011 | Brother IntelliFax-2820 Laser Fax
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
When faxing a document; it starts dragging the paper and the fax does not go through. In the confirmation message, it shows "communication error"
communication error means there's some interference on the line or if by dragging paper you mean it is crumpling it up then this will give the same error. Make sure there is nothing else dropped into the fax machine and make sure the paper guide is set correctly. You may need to use a different make or grade of paper
Jan 30, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
How do i get my fax machine to print out confirmation with 1st page faxed
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Oct 12, 2009 | Office Equipment & Supplies
Confirmation
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Confirmation sheet
Scroll through your menus and look for TX CONFIRMATION set it for incomplete only or never
Jul 16, 2008 | Brother MFC-8220 Fax
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Confirmation Sheet
It means that the fax was not received without errors. In other words No Good. Not that it literally means that, but all fax techs call it that.
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet M3035xs MFP All-In-One Printer Logo
671 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
