Question about Video Game Consoles & Games
System turns off after 5 minutes - Video Game Consoles & Games
  • snaptop Apr 27, 2008
    no thats not it. using all original stuff from sony.
  • 4 Answers
If you are using a third party power source, that's probably the problem.
Posted on Apr 27, 2008
Why does the air conditioner work for about 15 minutes, and goes off and not coming on again until you turn the switch off about 5 minutes and on again?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
If you need help with your system check out Boca Raton Air Conditioning Service
May 03, 2016 | Heating & Cooling
Van was stolen, key colum broken, keys gone, cant afford to replace, help please. I can get the radio on.
This may be related to the antitheft system The system is known for turning off the starter and/or injectors when it fails. Is there a light on the dash that says SECURITY? This is a common problem worth looking into. http://www.diy-gm-security.com/
Dec 16, 2015 | 2000 Pontiac Montana
Furnace will not turn on even after the thermostat is programed. Thermostat is a Hunter 44155c
5 a. Check the Heat/Cool function switch to ensure it is set to the desired position. 5 b. Wait. There may be as much as a 4-minute delay before the system turns on or off to protect the compressor. 5 c. Check the circuit breakers and switches to ensure there is enough power to the system. 5 d. Replace the batteries. 5 e. If applicable, make sure the furnace blower door is closed properly. 5 f. If your system has 4 wires, ensure the jumper wire is installed between the RC and RH terminals.
Feb 03, 2015 | Hunter Dryers
How do i reset my theft system if the the factory radio is removed my 98 malibu
You should be able to reset it without the radio. Turn your key forward 2 clicks until right before the car would normally start, leave like this for ten minutes. (No less than ten. Eleven is safe) Turn the key back to the "off" position for 5 seconds and repeat the whole process 2 more times.
So that's forward 10 minutes, back for 5 seconds. Forward 10, back 5. And the final forward 10, back 5. Try to start vehicle.
This is a complete GM Passlock relearn. Should take about 30 minutes. If that doesn't work, you may have something broken. Normally, the passlock doesn't get triggered for no reason. So worst case scenario, you can always bypass the entire system. Here is a great link with a ton of info on Passlock and how to get around it
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 30, 2012 | Cars & Trucks
No start after removing ignition switch and lock cylinder.
These vehicles have a built in antitheft system. When switching the ignition you interrupt this system. You will need to do a system relearn after the new ignition is installed. It will not start until the new ignition is installed and relearned. Step one. Put key in ignition, turn forward 2 clicks until right before it should start. Keep like that for ten minutes, NO LESS. Step two. After the ten minutes, turn key back to off position for 5 seconds. You need to do steps 1 & 2 a total of three times in a row without trying to start the car in between. The whole process should take roughly 30 minutes. After the last time waiting 5 seconds in off position, turn key forward and attempt to start the vehicle. Remember no less than ten minutes when forward, maybe do ten minutes and 15 seconds to be sure, some people even do 11 minutes.
Oct 28, 2011 | 2000 Buick Regal
After 20-30 minutes work in the USB or AUX mode, the unit turns off. At display panel says PROTECTION. After that this problem (when I turn on) repeats after 3-5 minutes.
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Jan 16, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
When security light flashing,will not allow car to start,why??
Because you have to let the system relearn the keys for some reason. Its a pain in the nack but do this:
Turn key in the ignition to ON
Wait for 10 minutes.
Turn it OFF
wait for 5 seconds.
Turn it OFF
wait for 5 seconds.
Turn it OFF
wait for 5 seconds.
Start the car as you would normally.
Good luck.
Jul 11, 2009 | 1999 Oldsmobile Alero
DVD turned off automatically after 5 minutes
If you still have warranty go back to your vendor to have it fixed. Also you can check if perhaps an auto-power off is enabled.
Apr 10, 2009 | Philips HTS3450 System
Powermust 600 USB 5 minutes shuting down problem
Load is the problem. Too low load on UPS will cause that on almost all Musteks.
Dec 12, 2008 | Mustek UPS 600 (POWERMUST600USB) UPS...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
