Question about GE Spacemaker WSLP1100D Top Load Washer
On my wslp1100 model its very very hard to connect the hose to the faucet adapter, it just does not want to go in ,also it leak's a lot of water from where the hose connects to adapter , I have to wrap a towel around faucet .
Hi... I had the same problem. Instead of trying to figure out the faucet/adapter issue (was too pissed off) :) I took my old washer hose and just used that. Connect the washer hose to your sink and the washer just like it would be if you used that adapter hose. You will want to make sure it is tighten good or it will leak a little...and make sure that the adapter hose end is in your sink because that is where the used water empties out from.
Hope this helps.
Posted on Sep 03, 2010
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Leaking washing machine faucet adapter
fit the rubber washer into the adaptor that seals off on the tap face
can be obtained from any garden tap fitting
Jan 24, 2018 | Washing Machines
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
I have a Moen kitchen faucet with a leak.
By "leak in the stem" I assume you mean you're getting water in the cabinet below the faucet. High likelihood is it's the hose - either loose where it connects to the faucet or the sprayer. You can pull it out and check to be sure it's tight at the sprayer. To check the faucet end, you'll need to be under the cabinet with a light. If you don't find one of those connections loose, it's likely one or the other is leaking, due to a hose defect or washer (or missing washer).
The only way to see that is to turn the faucet on full (cold) with the sprayer pulled out and look for a leak in the hose behind the sprayer. If not there, leave the water running (may need another person to hold the sprayer) and inspect under the cabinet with your light for a leak either in the hose or at the connection to the faucet. If the problem is the hose or one of the nuts, it's an easy deal to buy a replacement hose - Home Depot stocks Moen.
Feb 02, 2018 | Moen Plumbing
Leaking faucet ff1280r846,1200r692underneath,when lever is open water is running below off spray nozzle..
hello. pull out the spray nozzle and turn on the water. The water is either leaking from the hose, or from the connection. If the hose has a hole in it you will have to replace it. If the connection is leaking, disconnect it [with the faucet off], put some teflon paste or teflon tape on the threads and reconnect it.
Aug 16, 2009 | Plumbing
The connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
Hello raymun30,
Welcome
You said,the connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
What is the Make and model number of your portable dishwasher?
And how old is it?
If I have the number can look into the repair manual and at the diagrams and tell you what part you may need.
Find the complete model number. Waiting your response.
Huuum
That connector attachment can be replaced!!!!!!
Oct 20, 2008 | Dishwashers
Connector hose
the water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Jan 30, 2008 | Danby DDW1805W Designer Series...
Faucet Attachment Leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Dec 09, 2007 | Maytag 22.1 cu. ft. Bottom Freezer...
Water leaks during rinse cycle
MAKE SURE TO FLUSH-OUT DRAIN LINE. WATER IF IT IS DRAINING TO SLOW WILL START LEAKING AROUND THE LOWER PART OF THE WASHER WHERE THERE IS A SAFTEY OVER FLOW ... IF YOURS IS A FREE STANDING TOP LOADER THE DRAIN HOSE IS IETHER SEPERATE OR FLOWS WITH A CHECK VALVE THAT HOOHS RIGHT TO YOUR FAUCET. MAKE SURE THE CHECK VALVE AT THE FAUCET CONNECTION IS FREE AND NOT STUCK.
May 07, 2007 | Kenmore Elite 20972
GE Spacemaker WSLP1100D Top Load Washer Logo
213 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
