Question about Kodak EasyShare DX7630 Digital Camera
I have a kodak easyshare dx7630 and it cant read a new memory card
  • kakima Aug 06, 2010
    What size is your new memory card? The DX7630 is designed to work with SD cards 2GB and smaller. If your new card is larger than 2GB then it's actually an SDHC card and will not work in the DX7630.
    Brigadier General:
  • 11,967 Answers
New cards must be formatted in the camera before using.
Posted on Aug 06, 2010
Why will it not format the new memory card? I have tried 4.
Make sure the little tab/switch on the card is in the proper position for read/write, then try to format the card on a desktop or laptop computer, using the FAT file system. Then pop it in the camera. It should read it.
Nov 21, 2015 | Kodak EasyShare DX7630 Digital Camera
Kodak Easyshare DX7630 Can't Tranfer Pictures
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Kodak's.
Apr 24, 2012 | Kodak EasyShare DX7630 Digital Camera
I have 2 different sd cards 4gb that the card won't format or read because it won't format it.
The DX7630 works with MMC and SD cards. Your 4GB cards are actually SDHC cards, not SD cards. While they will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jan 28, 2011 | Kodak EasyShare DX7630 Digital Camera
The camera won't format a scan disc memory card
How big is the memory card? The DX7630 uses SD cards. If your card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and won't work.
Nov 11, 2010 | Kodak EasyShare DX7630 Digital Camera
I have a Kodak dx7630 digital camera I always find a message saying that I have to format my memory card, and when I press "ok" it doesn't get formatted. I also find this message even if the memory card...
Remove off your memory card ffromthe camera and test this in your PC for possible errors. A scan for virus must be done and the card must open. If so format after saving off all the files.
Now reinsert the card to your camera, If the fault recurrs then it can be errors in the processor board.
Sep 12, 2010 | Kodak EasyShare DX7630 Digital Camera
Memory card fails to format
Try to buy a card reader and format the card from your computer first. If the camera is brand new and still able for return, return it.
Jun 04, 2009 | Kodak EasyShare DX7630 Digital Camera
Wanting to see if a certain memory card can be supported.
Based on your camrea's manual (I read it on Kodak's site), your camera will take an SD card so you will most likely be fine as long as you do not use the SDHD type (high density) . The SDHD's store more data and it seems to be newer cameras support this type, not the older. The Ultra II is simply a faster memory than the standard and I believe there is an Extreme type that's even faster. The speed is best when getting images off of the memory card. In camera buffers help get the data to the card. After you aquire one, format it in your camera.
May 01, 2009 | Kodak EasyShare DX7630 Digital Camera
Transfer pics from internal memory to Sims card
when reviewing pictures on the internal memory push the menu button. There is an option to copy the pictures to the memory card.
Nov 16, 2008 | Kodak EasyShare DX7630 Digital Camera
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Nov 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
161 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
