Question about Akai PT46DL10 46" HDTV-Ready Television
Scren turn off 2 minutes after open. The sound function ans i can change chanel but i lost image and i dont can set tv in the menu be cause image turn off
  • Akai Master
  • 11,800 Answers
I'm assuming that the bulb remains lit and no other defects are noticed - no weird sounds coming from the back of tv, no funny spots of light on the screen - and the OSD is also missing.
In a DLP projection only 2 things would generate a loss of the image: either the image processor overheats and fails or the connections to the DMD (the part that created the image) are loose. Without proper tools all you can do is to take the back cover off and reseat all wires and connectors. If this doesn't work then you must start testing (at least a good voltmeter is needed) - check the power to the processor and the signal level to the DMD.
Posted on Aug 06, 2010
My admiral tv 32 inc goj12390 dont have the remote control and i cant see the dvd on tv scren beacause is only on chanel 3, 4 and i can put it on aux or imput
This worked for my Admiral TV model GRD15272:
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input2_bing.gif to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Mar 08, 2010 | Televison & Video
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
My sony trinitron tv is off the normal chanel 3 an I cant get it back on there. I have AT&T CABLE my son touch the tv an switch the chanel. My problem is I dont have the orginal remote. An I have...
Hi, if you have a "menu" button on the front of the tv go into the menu & "auto-program" the channels, if your set does not have the menu button on the front you will have to call a local tv shop with the model number of your tv and they can order you one, gl, video-tek
May 18, 2009 | Sony Televison & Video
Lost Color after Speaker was too close to TV
Good Day, Props123;
It sounds like you may have locked-up the micro, try unplugging TV from wall for 3-4 minutes, then replug. If the TV was magnetized (crt) the osd would also display no color.
Good Luck, Big Irish.
Jul 08, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
Feb 10, 2008 | Televison & Video
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Akai PT46DL10 46" HDTV-Ready Television Logo
20 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
