Question about Garden
How do I wire the intermatic T8805 sprinkler timer. I have 110v.
  • 243 Answers
SOURCE: Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
Posted on Feb 14, 2010
MOTORWIZJ
  • 1384 Answers
SOURCE: how to hookup timer to existing old intermatic
I WOULD FIX THE ONE YA GOT IT NEEDS A TIMER MOTOR QUICK EASY FIX .. LOOK ON EBAY 24.99-4.00 SHIPPING, BUT FIRST SEE WITCH MOTOR YOU HAVE.. WG1573 ITS 230 VOLT ONE OR THE WG1570 ITS THE 115 VOLT THESE ARE A ROCK SOLID TIMER . I HAVE ONE FROM 1962 VOTE >>> JAY MOTORWIZ
Posted on Aug 03, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have an Intermatic R8815P101C
The 24 volt timers are set up for a completely different type of sprinkler system. You could make it work on yours, but you would have to re wire the whole system. And it would cost 10 times the amount of a new timer. There is no way around replacing the whole timer. You can replace the clock part of the timer, but it would probably cost as much or more than the whole timer. But I can tell you that if you oil the gears on the back of the clock a couple of times a year, it will make your timer last a lot longer.
Posted on Sep 13, 2010
SOURCE: Triing to install intermatic t103 please help.
T103 has 120Volt clock motor, so we can wire this timer.
T103 timer is rated for 30 amps and 2horsepower and your blowers use 28 amps.
So we're getting close to max on the timer. Hopefully blowers won't all be started at one time since motors draw maximum amperage when they start.
However, you need 30 amp breaker and orange 10 gauge wire for that much amperage >> unless only one blower is turned ON at any given time.
Always match wire size, amperage of breaker and amperage of Load or it will trip the breaker.
If you put 30 amp breaker on size 10 wire it is good. But 30 amp breaker on smaller size 14 or 12 gauge wire is fire hazard.
http://waterheatertimer.org/Color-codewire.html
Add a comment at any time, and I will respond
Look at the basics:
You have 2 cables.
One cable comes from breaker box.
Other cable goes to three 120V plugs (120V is same as 110V).
Each cable has black-wire, white-wire and bare-copper-ground-wire.
How to wire the timer.
Timer has 5 terminals: A 1 2 3 4
A) Cable from breaker box:
White wire from breaker connects to terminal A
Black-wire from breaker connects to terminal 1
B) Cable going to 3 plugs
Black wire to plugs connects to terminal 2
White wire to plugs connects to terminal A
Ground wires connect to green ground screw.
Terminals 3 and 4 are not used in this case.
Here is a wiring diagram that shows 120Volt from breaker box and 120Volt going to Load
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Posted on Nov 27, 2010
Testimonial: "Great help quickly thanks"
SOURCE: My Intermatic sprinkler timer's 'auto" switch
You can replace the 133T1115A switch if that's the suspect part:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Other than the switch, the only other thing affecting timer would be the trippers.
Posted on May 21, 2011
Orbitz irrigation timers
Intermatic sprinkler timers, 12 hour on-off is possible plus day skipper option, and rain gauge connection etc::
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
More sprinkler timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link above includes sprinkler timers on market today
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 03, 2013 | Electrical Supplies
T8845pv
You have 120Volt Intermatic sprinkler timer with 24Volt output.
Copy following link for setting sprinkler timer:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Copy following link for wiring Intermatic sprinkler timer:
Add a comment
lllllllllllll
May 25, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
How to install t8805p101c
T8805p101 is 120Volt timer with 14-day skipper wheel that is made for sprinkler systems or pumps up to 1/2Hp.
Copy following links for wiring diagram, manual, and general instructions for setting and repairing T8805p101.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8805
Jul 23, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
I have disconnected the internal wires from my Automatic Sprinkler Timer model R8806P 101C . and don't know where they are supposed to go. Is there a diagram of that? Specifically, where does the...
Thank you for including model number of product.
R8806P101C is 240Volt timer with 4 wiring terminals.
You removed factory wiring and want to reattach.
The on-off-auto switch does not have separate wiring diagram.
Intermatic offers tech support phone: 815-675-7000
Add a comment and say what you discover.
Open following links for resources:
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
Aug 19, 2011 | Intermatic R8806P101C -...
Have a intermatic sprinkler timer that is has been reconnected to the pump. it works in the manual mode but the timer does not work looking for help on the wiring (video for dummies preferred)
No video.
If manual override works, look to see if dial rotates on time for full 24 hours. If dial keeps good time, then timer clock motor is wired correctly. If dial stops rotating after tripper passes, then wiring is wrong. If trippers are absent or worn down then timer will not turn Load on-and-off.
How to set timer, and troubleshoot timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
How to wire timer:
You posted under R8806P101C 240Volt timer without rain sensor connections.
http://waterheatertimer.org/pdf/Intermatic-r8806p101c-manual.pdf
If this is not your timer, then add a comment with model number that appears on door panel.
The wiring block has 4 screw terminals. From left to right: 1 2 3 4
240Volts cable has two hot leads from breaker box. Hot leads from breaker box connect to screw terminals 1 and 3.
Timer operates 240Volt pump load. Cable to pump load has 2 wires. Connect Load wires to terminals 2 and 4.
Open following link for resources:
Jun 28, 2011 | Intermatic R8806P101C -...
How do you wire a Toro Rain Sensor 53769 to Intermatic Timer T8845PV
The rain sensor only connects to Intermatic sprinkler timer IF the timer has the rain sensor terminals.
Not all Intermatic sprinkler timers have that connection.
For example R8815P101C and R8816P101C have rain sensor terminals
I think the rain sensor terminals are located to the right of main wiring terminal block.
There are two screw terminals.
The rain sensor plugs into a power source, and then sensor wires connect to the timer.
Apply no voltage to the sprinkler timer terminals.
May 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
May 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Garden Logo
233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
