Question about KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator
Ice maker not making ice red light flashing 2 times
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
SOURCE: Red Light Flashing by Ice Maker on and Off switch
Red light flashing and NO ice. I used a hairdryer to hopefully clear the frozen waterline and it made 1-ONE row of ice and stopped and the red light still flashing. help!
Posted on Nov 12, 2008
  • 531 Answers
SOURCE: My Kitchenaid side-by-side KSR125F isn't making ice
1 check frost build up in freezer 2 water valve or icemaker
Posted on Apr 07, 2009
SOURCE: My red light is flashing in my Kitchenaid side by
If the filter is clogged (0% left), you may not get the water you are looking for.
Posted on Jun 22, 2009
  • 523 Answers
SOURCE: ice maker wont make ice, light blinks twice in a
the eyes are bad
Posted on Jul 09, 2009
Zb01 ice maker
Hi need help my ice maker red light keeps flashing , it a platinum portable counter top zb01 maker what can be wrong
Jun 02, 2013 | Refrigerators
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Flashing red light on ice maker control
Hi
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Thanks
Jul 16, 2009 | Whirlpool Refrigerators
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Oct 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Changed filter, red light flashes, not making ice at all
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Logo
46 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
