Question about Samsung DVD-V5500 DVD Player/VCR
No power. (The power plug is connected to the wall outlet.
  • fmart41 Aug 06, 2010
    Yes it was helpful. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please try a different power socket and check that all the cords from/to the DVD Player are connected firmly. If still the issue is not resolved then the circuit board inside the unit has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
    must be the circuit board. do you have an adress for a local repair shop? (austin, tx)
  • Rylee Smith
    Rylee Smith Aug 06, 2010
    Please check this link for local repair centers in Austin, TX. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Help tv show power but dont wanna switch on?
Unplug the cables from the console, wall outlet, and power supply itself. Wait 10 seconds. Important Be sure to wait 10 seconds. Firmly plug the power cable back into the console, and then plug thepower cable back into the electrical outlet and the power supply. Connect the power supply directly into a wall outlet...
Apr 13, 2017 | Televison & Video
After charging battery,the phone dial reads, out of range,or no pwr at base
Double check that the power cable is _fully_ plugged into the phone base, then check to see that power cable is fully plugged into wall outlet; and/or fully plugged into phone wall outlet. (Some base units have no power adapter and get their power from the phone outlet on the wall). In short, double check _all_ wired connections. Do not assume they are fully plugged in.
Aug 15, 2015 | Vtech VT-CS6114 Cordless phone w/ CID/...
My screen turned blue and I can't change it back.
Try unplugging it from the wall outlet. Press the power button once to release any stored power. Plug it back into the wall outlet and turn power back on to see if this helps. If it is connected to a cable box make sure all the cables and connections are not loose. Check to see if the cable box is loose from the wall outlet.
Mar 31, 2015 | Samsung UN46D7000 46 Inch 3D 1080p Smart...
My epson sx130 won't turn on
Check the following:
  • If the all-in-one is plugged into an outlet on a power strip, try plugging it directly into a wall outlet.
  • Make sure the outlet you're using isn't controlled by a timer or wall switch that could be making the outlet inactive.
  • Make sure the power cable is securely connected at both ends.
If the issue persists, the hardware itself is malfunctioning and will require service
Sep 24, 2014 | Epson Stylus Office Equipment & Supplies
Inspiron 2305 power cord doesn't turn the desktop on
After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
Sep 18, 2011 | Dell Inspiron One 2305 Desktop Computer...
Ac adapter is red, what should i do?
This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if:
  • There is too much current.
  • The voltage is too high.
  • The temperature of the power supply is too high.
When any of these things happen, the light on the power turns red.
Solution 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
  1. Turn the console off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
  3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
  4. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on.
If the power supply light is still red, try the next solution.
Solution 2: Make sure that the power supply is plugged in loadTOCNode(2, 'whattotry'); Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution.
Solution 3: Plug the power supply into a different wall outlet loadTOCNode(2, 'whattotry'); To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution.
Solution 4: Order a replacement Xbox 360 power supply loadTOCNode(2, 'whattotry'); If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
To help the power supply work correctly, follow these guidelines:
  • Do not block any ventilation openings in the power supply.
  • Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply.
  • Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector.
hope this helps.
Apr 10, 2011 | Microsoft Xbox 360 Console
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
Hp psc 2410 photosmart all-in-one
I have a questions for you, is the unit connected to a surge protector, or to a wall outlet.
If its connected to a wall outlet then the power supply will not be directly to the unit, as these units come with a built in surge protector in them.
You can try connecting the unit to a wall outlet, and if no go then try this step.
Disconnected the power cord from the unit as well as from the wall outlet.
Press and hold the ON button on the unit for 30 sec and then plug in the power cable to the wall outlet and then to the unit.
Remember to connect the cable to the wall outlet first and then connect it to the back of the unit.
This should probably fix the problem,
Please let me know if there is any other issues.
Nov 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
Samsung DVD-V5500 DVD Player/VCR Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
