Question about Refrigerators
I have a kenmore top freezer that is very hot on the outside of the freezer, is there any faster way to fix this problem then to unplug it for 8 hours?
    President:
  • 1,430 Answers
This is musually caused by the condenser fan not running or the condenser coils are clogged up. This is easy to check and replace. Here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Posted on Aug 06, 2010
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
When you open the freezer door the metal in hot to the touch
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 29, 2011 | Kenmore Top Freezer Refrigerator
Why on the outside of the freezer is hot on sides?
heatman101
May 21, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Dripping in the freezer, toward the bottom. Nothing has leaked outside. Wondering.
Water in Refrigerators
The drain tube is blocked, the easy way to fix this problem is lay on the couch. Unplug the unit to let the tube thaw.
Many, top freezers have this problem But, you have to make sure the
Refrigerator is unplug long enuff to melt the ice. The food must be removed. I left my unit off for 12 hours.
I'm sure there's a professional way to do this, but, like the couch.
Idea better. I've herd many way's to fix this problem some cost $$
and, still don't fix the problem
Sep 12, 2009 | Kenmore Refrigerators
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Sep 11, 2009 | Kenmore Refrigerators
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
Outside freezer is hot to the touch
Its normal, the heat is coming from the condenser which is integrated within the freezer cabinet and is completely out of sight.
Jul 10, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
