Question about Goldstar Dehumidifiers
Goldstar dehumidifier Mod#GHD30Y7 After working well it simply stopped. The water bin is empty and the internal fuse is okay. Is there something easy I could check to fix it? Brent
    President:
  • 670 Answers
The first thing I would check is to see if turning the humdity switch to lower the humidity turns the unit on. Then if that does not work, I would check to see if the bucket is making contact with the switch. It the switch that shuts the dehumidifier off when the bucket get full of water. Sometimes you can hear it click when the bucket hits the full state.
Not sure how technical you are, but if you are familiar with how to use a meter, I would check the bucket switch. I would check to see if the switch changes open/close depending on whether the switch is pressed.
If the switch is good, listen for any kind of hum from the unit. That could mean that the compressor, is unable to start. That could either mean you need a new compressor of a capacitor.
Hope this helps you.
Posted on Aug 06, 2010
I have GHD30Y7 that runs but will not extract any water. Thoughts!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 13, 2011 | Goldstar Dehumidifiers
My Goldstar Dehumidier quit working... there is no collection of water off of the coils making it useless. What can I do?
Have you checked to see if the collection basin is full. If so empty it and it should start.
May 02, 2011 | Goldstar DH304 Dehumidifier
My Goldstar model GHD30Y7 turns on and runs, however, it does not collect any water. What is wrong with it?
heatman101
Oct 10, 2010 | LG DH30 GoldStar Dehumidifier
Does it need a hose in the back
The hose is optional.You will have to empty the water bin every now & then yourself when full.The hose drain has to run to a sink or floor drain for convienece if the unit is HIGHER THAN location.
Mar 31, 2010 | Goldstar DH304 Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
Suddenly stopped working
remove bucket, look under for the bucket overflow switch, try tugging it a bit, may have gotten stuck when you pulled out the bucket
Jul 24, 2009 | Goldstar DH304 Dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
May 21, 2008 | Goldstar DH304 Dehumidifier
Dehumidifiers Logo
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
