Question about Microwave Ovens
I have discoloured the enamel surface on the top plate of my oven,Leisure Rangemaster 110, the only explanation i can think is two days prior i was removing varnish from some stained doors with nitromors and i used the same cloth as i wiped over the doors in soap and water is it possible a vey diluted solution has caused this??
  • brianbakerph Aug 06, 2010
    I have already faded or discoloured the rangemaster oven not microwave. im asking is there anything i can do????
    it was suggested car polish would remove it, im afaid no it hasnt budged it at all.
    Any other suggestions
  • 10,515 Answers
Nitromors are used to remove oil based paints, enamels, varnishes, shellac, cellulose, plastic coatings, lacquers, stove finishes, polyurethanes, emulsion paints, synthetic finishes, French polish, tar and many other coatings.
So, yes - i would say that more likely this product would have caused discolored enamel surface on the top plate of your oven.
Good Luck!!
Thanks!!
Posted on Aug 06, 2010
  • taran_2005
    taran_2005 Aug 06, 2010
    Thanks for your response!!
    Unfortunately, there is nothing much you could do.I am sorry, but it's always better to be honest.The enamel surface is already destroyed. You cannot restore it.Trying different products might make the situation worse.
    Good Luck!!
    Thanks!!
  • Microwave Ovens Master
  • 11,800 Answers
Nitromors is quite strong but i doubt that it could do that, especially if it was highly diluted. But if the unit is old (at least 5 years) ,well used, then the enamel was weakened by constant heating and cooling so it's possible, especially if the discoluring is very superficial. In that case to fix it all you need to do is to polish it with car polish.
  • 2 more comments
  • Azrael SRL Aug 06, 2010
    As i said, since the solution was diluted and the enamel strong then most likely it's just surface deep. All you need is to polish it away. Use any brand of car polish (not car wax or similar, polish) and just rub the affected area, the discolored layer will be wiped away.
    car polish hasnt budged it
    car polish hasnt budged it.
  • 4,323 Answers
Hi
Nitromors is a very strong solution and can cause the paint & varnish to remove very easily. It can cause the enamel to fade away easily. Please use the nitromors carefully and throw away the cloth that you use with nitromors.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
The dark brown enamel has been damaged about 1"square on base of the inside of oven Are there any enamel repair kits?
you can buy enamel white or clear, and mix in pigment to match your colour, most diy stores carry the enamel you could ask them for the pigment as they can maybe get hold of the right color. or by from ebay the pigment.
Dec 06, 2017 | Microwave Ovens
What's the best way to protect water based enamel paint? I painting a night stand for my daughter and I don't want it to scratch easily. Oil based enamel is more durable but its not an option.
try painting it over with a 2 pack clear epoxy paint
2 pack epoxy paint is about the hardest surface you can get and the clear finish will show the original paint color through
or paint it again using the color in epoxy 2 pack paint
Talk with a professional paint supply shop
Mar 22, 2017 | Microwave Ovens
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Mar 31, 2011 | Microwave Ovens
I have a Goodmans Microwave ME20W in perfect order except someone has misused it and the paint under the rotating plate is blistered causing the oven to crackle in use. There is also one small area of...
Yes they can be cleaned. prepared and painted with enamel paint.
The reason the paint comes off is usually due to condensation as the oven is left with the door closed after use.
Mar 14, 2011 | Microwave Ovens
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
Flash in oven
The flash is usually caused by metal either being placed inside of micro or the interior surface might have chipped enamel exposing the metal underneath. Make sure no metal materials are placed inside while using and that the interior surface is in good condition.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
