I have a novi tech paper shredder model PS-064/B That has a stripped gear that meshes with the motor. Where would I find a gear?
fellowesrep
  • 102 Answers
SOURCE: paper shredder gear is stripped.....replacements?
Best bet is Royal Customer Service at 888-261-4555
Posted on Mar 02, 2008
  • 8 Answers
SOURCE: Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
  • 8404 Answers
SOURCE: Officemax OM96580 has a stripped gear tooth on the
If you expect to repair this, expect to spend weeks waiting for parts if you can get them at all, at least an hour to do the work and expect to spend 2/3 the price of a new one for the parts.
My advice, my friend, save the collection can, discard the shredder. On your new shredder, dont over feed it.
Thanks
Posted on Oct 14, 2009
SOURCE: NoviTech Paper Shredder will not feed paper forward.
Solution 1 worked for me. I unscrewed all 7 screws, pulled apart the cover carefully. Beware, there are wires attached. you can lay it side by side.
The activator is the white plastic thing. You need to make sure that it sticks out and as the paper goes from the top, through the cover, it hits the white activator.
At the end of the white activator, you see it has some plastic to push on the metal strip. This engages the forward motion. You'll here a click if you test the paper going through. This click is the sound of telling the motor to roll forward.
I think it got knocked out of place when I tried to insert a CD into it. Luckily, I didn't buy another shredder because of the Best Solution in this forum. So thanks for your help!
Posted on Aug 01, 2010
  • 41 Answers
SOURCE: The plastic gear in my Fellows Powershred PS 60CC
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Posted on Sep 22, 2010
Fellowes Shredder PS-79ci Motor runs but teeth won't engage, paper sensors work so if I remove paper the motor stops. And, I oiled it.
No doubt the gears (usually plastic) have stripped off and they do not make replacements .made cheap not to last for lifetime so they sell more
Sep 20, 2017 | Fellowes Office Equipment & Supplies
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
Gears are not rotating; motor works though
I guess you have made sure that the cutters are not jammed by bits of paper and card?
Mar 23, 2014 | Office Equipment & Supplies
Need a manual
Can I purchase the plastic geers for a novi tech shredder. Model: PS-307B. Mine stripped.
Oct 25, 2012 | Office Equipment & Supplies
I have a privay Guard model PS-029/MB and I have a brocken plastic gear, can I find this part online?
I have the same problem. The gear that the motor drive shaft touches has been shredded to pieces. when contacting the second gear. The secondary gear is plastic and absolutely WILL shred itself to pieces over a short lifespan (<5yrs) because metal vs plastic is a losing combination.
Feb 02, 2011 | Techko Identity Guard 6-Sheet Strip Cut...
Will not feed paper in
Most likely a gear has either stripped or broken inside the shredder. That model has been discontinued for quite sometime and no parts are available for it.
Jan 22, 2011 | Tech Solution TS-4500 Shredder
Officemax OM96580 has a stripped gear tooth on the nylon gear that meshed to the motor pinion gear
Thanks
Oct 14, 2009 | OfficeMax 0M96431 Shredder
Powers on but not grabbing the paper.
Open the top and check for stripped gears...call Royal at 1-800-524-0799 for parts and prices.
Sep 14, 2009 | Royal 29099S-CX HT700 770X Shredder with...
Royal HT700x will not cut help
Mine makes noise in both directions but is not cutting like it used to. So I took it apart tonight and found a stripped gear in the gear reducer train. The motor and some of the gears makes noise but then the connection to the cuttings is discontiuous. Now I need to try to find a spare part. This may be your problem.
Jun 11, 2007 | Royal 29099S-CX HT700 770X Shredder with...
k24674
jasbo
jasbo
Marvin
Marvin
