Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper jamming and feeding unevenly
As the paper feeds into begin printing its feeding in on the right hand corner and feeding unevenly causing a paper jam. I have run a self clen of the roller and to no avail??? Mp210
  • 2 more comments
  • marilocz May 02, 2008
    we cannot get the printer to get the paper evenly it keeps feeding it the wrong way? what can i do? we already did the cleaning and it still doing the same thing
  • julezy May 03, 2008
    I am having the same problem the right hand side of the printer feed.
  • teddybear_29 May 08, 2008
    yes have the same problem paper will not feed in printer right it trys but only one side.. nothing seems jammed? paper will not go in.
  • Anonymous Sep 24, 2008
    Paper pulls into the right and then jams! No wonder Canon were giving them away with a £15 cash back!!!
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
Paper is constantly jamming on right hand side-as you face printer-it feeds in unevenly as soon as I start to print.
Remove all print paper from the paper tray. check if there are any dust particles or any other substances that might be jamming the paper. That is the only fix.
Dec 20, 2010 | Epson Stylus RX650 All-In-One Printer
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
Paper wont load
Check the feed rollers, (IF you do a alot of printing), the feed rollers are slick with paper dust, and are causing the jam, You can clean tyhem by taking out the paper, and clean the roller with a cloth rag and some 409 cleaner. scrub the feed roller to remove the paper dust, then let the rollers dry, then re load paper and begin printng
Jul 21, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
645 people viewed this question
old marine
old marine
