Question about Canon Office Equipment & Supplies
How to print envelopes on Canon printer MF3200
  • 3 Answers
SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
rhoncruz
  • 134 Answers
SOURCE: How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Posted on Dec 01, 2008
SOURCE: Printer Error When Printing Envelopes
I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
Posted on Dec 05, 2008
SOURCE: how to print envelopes on
press print
Posted on Jan 02, 2009
efs_perpends
  • 1996 Answers
SOURCE: Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Posted on Apr 10, 2009
How do I print on A4 envelope with Canon ir 4080i photocopy/printer machine?
in printer just put your envelope portrait position, then set your paper setting into envelope size in your laptop or PC and just print it
in photocopy machine just adjust the input tray into envelope size than put envelope printed face up, and just print it
Feb 18, 2015 | Canon Office Equipment & Supplies
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
May 30, 2012 | Canon PIXMA MX310 All-In-One Printer
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Ineed asoftware for canon printer mf3200 for windows 7
You can download the drivers for this Printer from the following link.
http://downloadnew.biz/software/canon-mf3200-driver-windows-7/
Hope this helps. Good Luck.
~SmokinJoe~
May 26, 2011 | Office Equipment & Supplies
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Note:
    Note:
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing envelopes
Sep 17, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
166 people viewed this question
old marine
old marine
