Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
How to take apart the canopy to wash fabric - Simplicity for Children 4-in-1 Convertible 3045 Bassinet
Removing fabric for washing
Hi! Were you able to figure it out? I am having the same issue and it is driving me nuts! Lol. I dont get hoe the instructions dont provide details for fabric removal! Please let me know if you were able to get it off. I got mine second hand and it is filthy. :(
Feb 14, 2012 | Kidsline Premium Bebe Fina BF9111 Crib
I can't remove the canopy on my graco snug ride car seat to wash it. I'm having trouble separating the two parts to get the material off.
The two plastic pieces clip together inside the fabric of the canopy, but if you push the fabric all the way to one side, you can expose the latch where the two pieces meet. The two pieces are identical, so you can push in on the tab on either piece to separate them. You have to push firmly, but they should separate easily.
Once you've washed the canopy, just thread one of the plastic pieces through the canopy and snap the two back together by sliding them together.
Hope that helps!
Aug 20, 2010 | Graco Snugride
I am trying to take this apart to wash it, i cant get the canopy off and its all attached
U cant take them off. U have 2 wash it attached. use hot water and washing power, once u have it clean hose it off outside. it will come up like new. make sure its a hot day out or it will dry with water marks that may stain the fabric.
Jul 31, 2010 | Evenflo Journey Elite Travel System - 3...
Bebe Fina bassinet with no instructions--not sure if I have parts
Hi there, I have instructions for a bebe fina bassinet, not sure what model but will fax them to you if you have a fax number, cheers.
Jun 18, 2009 | Kidsline Premium Bebe Fina BF9111 Crib
Taking apart the canopy to wash.
you have to unhook the tabs for the canopy that is located by th button that pushes the carrying handle back
Mar 12, 2009 | Graco Infant SafeSeat (Step 1) 8A05RXY in...
Sun shade
I got this from the manual. I attached pictures from the old and new model for the peg peregeo Viagggio. Once the canopy is off you should be able to remove the fabric, just make sure to use the care instructions if you are going to wash it.
Good Luck from Moms Just Know
Nov 30, 2008 | Peg Perego Primo Viaggio
Graco Snugride canopy
Slide the fabric all the way to one side to expose the center clasp (hook). Then using both hands grasp the clasp like you were putting you hands on handelbar (placing your thumbs under the bottom of the clasp about 1 inch apart). Then push up with your thumbs while pulling down with your fingers (which should be wraped around the outside of the clasp). You will need to push with your thumbs all the way up in order to separate the two pieces (note - it feels like you are going to break it but you wont).
Putting them back to gether is just a matter of aligning the tabs in the slots and pressing the two parts together.
Nov 24, 2008 | Graco SnugRide 8646 - Fiesta
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
I have a 3112doh Winnie the Pooh bassinet
I could not get the fabric off my canopy either. I found it slide nicely into my washer (top loader with agitator) even with metal insert. I washed on delicate and it came out great, with no damage to canopy.
May 29, 2008 | Simplicity for Children 4-in-1 Convertible...
Graco bassinet model 3300
http://www.babyage.com/icons/localhost/products/multimedia/10186_RocknRollBassdir_12_17_03.pdf
Dec 01, 2007 | Graco Simplicity Rock n Roll 330 Crib
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
165 people viewed this question
Top Simplicity Baby Gear Experts
Charles T Nevin
Charles T Nevin
Marvin
Marvin
ray gallant
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
