Question about Goodman CKL60AR60 Air Conditioner
Does the out side unit need to be cleaned - Goodman CKL60AR60 Air Conditioner
    Scholar:
  • 80 Answers
Yes! This will help in the unit rejecting the heat from the refrigerant that just absorbed heat out of the air in your home! I use a foaming style cleaner for the coils. It helps push out the crud that has been built up over the season. This is a huge aid to the efficiency of the unit and the lower cost of energy bill
Posted on Aug 22, 2010
    President:
  • 3,074 Answers
With a condenser cleaning coil. Nu Brite is good just make sure you mix it right and wash it all off good.
Posted on Aug 10, 2010
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
Getting the message clean drum. Clean corona wire of drum unit. Need instructions on how to clean unit. What parts to I need?
You do not need any parts, just do the following.
1. open the front toner cover
2. take out toner and drum together
3. on the back side of drum unit you will see green or purple slider (it is used to clean corona wire)
4. push that slider few times from left to the right.
Important notice: you must leave slider on exact position to match black arrow on the drum unit.
BR
Sep 12, 2011 | Brother IntelliFAX 4100 Laser Fax
I JUST BOUGHT ALL NEW CARTRIDGES AND THE LEFT SIDE OF THE PAGE PRINTS REAL LIGHT. THE RIGHT SIDE IS FINE. I HAVE CLEANED THE SYSTEM WITH AIR.
The developer blades in your imaging unit needs to be cleaned. You can fix it by replacing the imaging unit for $100+ or you can clean them yourself. I have a link describing how you can do this.
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Oct 29, 2010 | Samsung CLP 300 Laser Printer
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
I have a Hotpoint CSX22D side-by-side no frost refrigerator. The refrigerator side is starting to freeze some fruits and vegetables. Any ideas as to why? I don't know how old the unit is - it was in the...
Hi!!
Try lowering the temp. setting for the fridge one click at the time. (wait 24 hrs. between adjustments).
If unit is cooling fine, there is no need to spend money on check up. You can clean the compressor compartment with your vacuum cleaner. Just unplug unit before you do it. There is also a little fan that needs to get cleaned with a degreaser moist rag,
Don't forget to rate this post. Good Luck,
May 08, 2010 | Hotpoint 21.7 cu. ft. Side-by-Side...
Water dripping inside room
Unit needs to be slightly tilted to the out side. or drain pluged and dirty is the unit clean? to properly clean you have to pull take apart to clean
Jun 17, 2009 | Fedders X Chassis A6X08F2A Air Conditioner
My inside air conditioner fan isnt turning on whats wrong?
If the in side blower motor turns off with the out side unit normal operation if the thermostat in the auto position set for cooling If the out side unit run with out the in side unit the out side unit will be wrecked . sounds like you need service and have it cleaned for best performance . Tom
Jun 17, 2009 | Heating & Cooling
Clean the condensor
You can clean the condenser while it is running or you can unplug unit . most of the time you can use a nylon brush to brush off the condenser. If it has not been cleaned in a while you may need some sort of compressed air to blow through it. If units are in restaurant and by fryers or have greasy buildup on them you will need to unplug unit and spray some degreaser on it then rinse with water. It is important to clean the condenser, the part with fins and is located by compressor, because a dirty condenser will shorten the life of the compressor.
Dec 19, 2008 | Delfield 'New 6000XL 6051 Side by Side...
My Samsung CLX-3160FN prints with the left side of the page being very light, while the right side appears normal.
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Nov 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Goodman CKL60AR60 Air Conditioner Logo
24 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
