Question about Poulan Ght225 25cc Gas Hedge Trimmer
Need to know how to replace the choke lever on weed eater GHT 225, and need a picture of the machine cause some things popped up and don't know how they should be reassembled.
3 Suggested Answers
  • 154 Answers
SOURCE: what is the gas/oil mixture rate?
50 to 1
Posted on Aug 03, 2009
  • 122 Answers
SOURCE: removing clutch from a weed
Here's a video of trimmer clutch removal which is similar to the clutch removal on your hedge trimmer:
http://www.ereplacementparts.com/article/1771/How_to_Remove_a_Trimmer_Clutch.html
Posted on Sep 01, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Air filter replacement weed eater
    on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
    Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
    Weed eater xt 260 choke lever is broken...can it be replaced easily
    It is not listed as a replacement part on the carburetor. You would have to remove the choke plate, and the choke shaft from the carburetor. These parts are press-fitted into the carb housing and the choke lever is also press fitted onto the choke plate shaft.
    May 25, 2011 | Garden
    How do i repair a choke lever in a weedeater te475y gas trimmer? Does the lever pull straight out of the carburetor.
    Upon inspection of this model machine, it appears that the choke lever shaft is pressed into place when the carb is manufactured. Removal may be possible, but probably more damage will occur. I have this same model machine with a Zama carb having flooding issues after soaking in a bath-type solvent overnight. This is NOT recommmended.
    Here is a parts breakdown for your machine:
    http://www.ereplacementparts.com/weed-eater-te475y-gas-trimmer-parts-c-17589_17626_18141.html
    Unfortunately, there is no avaiilable release date for the part you need in question....On the page I made available it is part # A800 or A801...depending whether you have the Walbro or Zama carb. Mine has the Zama.
    Jul 09, 2010 | Husqvarna Garden
    Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
    Three (3) possible carbs were available on your machine.
    If you have:
    Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
    If you have:
    ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
    If you have:
    ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
    Hope this helps.
    Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Sthil weed eater will not run when hot?
    you will need to replace you muffler so the machine can get rid of it's exhaust
    Jul 23, 2009 | Garden
    Echo weed eater, edger and blower wont start.
    TRY TAKING THE MUFFLER OFF AND CLEANING THE SMALL SCREEN OR JUST REPLACE THE SCREEN
    May 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    Poulan Ght225 25cc Gas Hedge Trimmer Logo
    121 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    roeb
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
