Question about Kenmore 22422 Top Load Washer
The washer was running with a full load. Suddenly, it stopped and made a buzzing noise. The noise sounds liked the motor got stuck, and cannot run. Water is still inside the drum. How can I restart the motor? I put the rotating switch from pre-wash to rinse, to spin and/or drain. The motor keeps making the buzzing sound, but nothing happens. Please help! Thank you so much for your help and consideration.
  • Danny Dao
    Danny Dao Aug 06, 2010
    It is Sears King size Quiet Pak 2, 3-speed motor with 6-speed combination. The front panel looks like the Kenmore White 800 4.0 cu ft by this link
    http://www.sears.com/shc/s/p_10153_12605...
    Brigadier General:
  • 3,513 Answers
Hi
See if your "drive motor to transmission coupling" is broken.
Check your motor coupling, it's between the motor and transmission, usually it breaks when the machine gets out of balance. Go to www.repairclinic.com and enter your model number. Then scroll all the way down and click on the red 100 this will bring up 100 parts per page for your washer. This part is located between the motor and the transmission. It's fairly easy to get to. Look at it on the site so you know what to look for. When you have it tilted you can set the timer to spin shut the lid and have a helper turn the washer on at this setting both end of the motor should spin the one end for the pump and the other end should spin the basket only do this long enough to see them spinning if the transmission side doesn't spin the replace the drive motor to transmission coupling.
Also check this link bellow…
http://www.repairclinic.com/Washing-Machine-Troubleshooting
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 06, 2010
Buzzing under hood of truck but disconnect batery and it stops
The buzzing is probably coming from an electric motor that is stuck or a relay that is stuck closed. You are probably going to need an automotive electrician to run down the problem. If it is an electric motor, the motor will get hot to the touch. Does your heater motor work? Does all the electrical system operate properly? Check all your electrical system. To isolate the problem pull one fuse at a time then put it back if the buzzing doesn't stop when the buzzing stops, you have isolated the circuit. Then you can take it to a mechanic and have it fixed.
Apr 11, 2014 | 2003 Volvo S60
Motor won't turn
motor winding's are faulty .replace motor and you are back in business.
Mar 14, 2014 | Maytag MAV7600 Top Load Washer
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Speed Queen Model SWT220WA 3/4 filled with water, loud buzzing sound, stopped.
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
Aug 28, 2009 | Speed Queen SWT921 Top Load Washer
Dryer won't start 7yr old dryer, was working fine yesterday, today was making strange buzzing noise while running, stopped it to check, and now won't turn back on.DEAD
Sounds like a defective motor starter contactor. DO NOT continue to try to use the dryer or you'll burn the motor out. The motor starter is built into the motor, but most are replaceable without replacing the entire motor.
Could also be the motor, but sounds like the motor is stuck in 'start' mode and never goes into 'run,' which would be the classic symptom of a stuck motor start contactor.
Jun 14, 2009 | Dryers
My Maytag top-loading washer does not run. It was o.k. until tonight. When I put the indicator at the 'start' position, it just buzzes, as though it wants to start but can't. Yet, when I put the...
this is really hard to say without actually testing it but it sounds like the timer contacts may be stuck so on wash the timer is telling the motor to go forward and backwards at the same time.
Jun 13, 2009 | Washing Machines
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
My washer is making a buzzing noise and stopping the process.
Yes sounds like the drain pump or sump area is clogged. Axcess throug lower service panel if the model you has selected is accurate..
Jan 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 22422 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
