Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
When I turn the computer on, it says "disc read error. ctrl, alt, delete to restart" and when I hit ctrl, alt, delete, the same message comes up but the computer won't re-boot
  • 62 Answers
Its likely because of hard disk failure. Try replacing the hard drive.
Regards
Sherbaz
Posted on Aug 06, 2010
Get error message at boot up Asus Eee 1005pe net book one year old. 'a disc read error occurred press ctrl-alt-delete to restart'
sounds like your boot ini file is corrupt if you have os disc put it in and try and repair.otherwise you may have to reformat hard drive
Jun 20, 2011 | ASUS Eee PC 900 Notebook
How do i fix a disc error on my acer aspire
Make sure you do not have any devices plugged in to the computer like a USB flash drive or a MMC. Usually what you have to do about that is to drain the power of the computer. Turn it off, remove the battery, unplug the AC adapter and then press the power button for 5 secs. Turn it on using the AC adapter alone. if you still get the same message, You will have to physically open the back of your laptop and reseat the Hard drive. If it still wont correct the problem, restart you computer and either press f2 or delete to enter the BIOS page. check if the HDD is properly detected and try to reload the BIOS defaults. now if any of these wont work, call ACER and most probably your Hard Drive is bad.
Jun 12, 2010 | Acer Aspire 3680 Laptop
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
It's giving me a disk error... A disk error occurred press alt,ctrl, and delete to restart and when i do that some message pops up.
There is a problem with your hard drive. Try taking the hard drive out, remove the battery, push the power button for approx. 10 seconds. Re-install the battery and re-install the hard drive. If the same message comes up again, try to boot the computer off a windows installation disc. If this all fails, you just may have lost your hard drive.
Sep 11, 2009 | Compaq MV 540 15" CRT Monitor
Trying to restore Dell Inspiron 1501 to factory settings.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
http://virusremoval.vpweb.com
New York
Jan 27, 2009 | Dell Inspiron 1501 Notebook
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
A disk read error occurred, press ctrl-alt-+delete to restart
Hello Sir
I am afraid that the hard drive is corrupt. It needs to be reformatted and reinstalled. There is also a good possibility that the hard drive will need to be replaced I am afraid. To make sure ask the technician or who will attend to it to disconnect the hard drive from your laptop. Plug it in an enclosure and copy all of its contents before reformatting. IF IT DOES WORK then don't let them trick you that it needs to be changed as it is just a case of corrupt files and a reformat / reinstall will do it good. In this manner you hit 2 birds with one stone and you get things back up and running :)
Hope that this solution helped you :)
Best Regards
Alx :)
Jan 07, 2009 | Sony VAIO VGN-N130G/W Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
