Question about Polaroid PDC 301 Webcam
Well i dont have a webcam on my laptop so i plugged this in, but it wont let me use it.
  • Polaroid Master
  • 3,015 Answers
In the webcam world things are not quite that easy - you need to download drivers (software to make hardware work) and then configure the webcam to any chat program you want to use it in
1) download the driver from here
http://www.bioticaindia.com/pdc-301.html
An example of setting up a cam in msn
Set your webcam mic (if it has one as default)
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Posted on Aug 07, 2010
Acer crytal webcam will not work 4339 series
try installing the drivers from the disc first then plug in your wecam in ,if you dont have disc then plug in the webcam and see if your laptop says,,found new hardware if it does let the windows go and find the drivers.
May 29, 2014 | Acer Aspire 5610-4648 Notebook
Webcam broken wire
your best option is to buy a new webcam for 20$ and attach it to your laptop, now that being said if you just cant live without your current camera you will have to find the replacement camera and cable open up your computer using a screw driver locate where those wires are plugged into your motherboard at remove those wires and install the new wires and lead the wire back up to spot where your camera goes then reassemble the laptop this is kind of tricky because sometimes these wires can be sautered on and non replacable also if you dont glue in your new camera right it wont face you correctly
May 15, 2013 | Computers & Internet
My webcam wont't turn on its a built in webcam on my Advent Laptop and when i try to turn it on it says no function.
try turning ur webcam on and off a few times if that dont work reboot. if ur webcam still not working check for driver updates if updates r available install and reboot. if it still not working call the manufacturer.
Jun 10, 2011 | Computers & Internet
I recently bought a webcam from 'computer gear' and its telling me i need the installation CD to download the software. i the webcam wont work without it, however IS working, because once plugged...
if you bought a webcam..there must be a small CD for the webcam driver.
if there is a hardware ..it needs driver to perform its work.
if you dont have webcam drivers CD ask the vendor.
May 19, 2011 | Computers & Internet
Dont install
Dear siahchaleh60,
try to install from CD that come with your webcam when you purchase them, or bring your laptop when you buy the webcam and find the webcam that plug and play support. Or run your recover CD that come with your laptop. used to be the recovery CD contain the driver for any connected device.
GoodLuck.
Best regards,
bionic23
Oct 28, 2009 | Sport & Outdoor - Others
Webcam doesnt work
Hey you know what !...its not problems with your cam or OS but its problem with MSN. Please use updated or NEW VERSION of MSN and then you will be able to use all features of your webcam while chatting on MSN or Yahoo!
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 28, 2009 | Acer Aspire 9300-3716 Notebook
Dark Screen, and Web Cam wont work
You might try going to add and remove and delete the webcam driver then reinstall it from the net or the cd that came with it.
May 24, 2009 | HP Computers & Internet
Acer crystal eye webcam
Try reinstalling the drivers
Mar 12, 2009 | Acer Aspire One PC Notebook
Dont know how to work webcam
plug the usb cable of your webcam to your pc's usb slot, whe windows detects the new hardware insert the cd driver that came with your webcam. then install the additional applications on the cd. restart your pc if it requires you to do so. otherwise open the application of your webcam and try it out. have fun!
Oct 28, 2008 | Acer Aspire 3610 Notebook
Polaroid PDC 301 Webcam Logo
107 people viewed this question
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
