Question about Canon PIXMA iP1800 InkJet Photo Printer
Hi, I am using canon ip6310D printer. I am getting an error code 5100 - Check printer, Can someone help to resolve this issue
  • 97 Answers
SOURCE: error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Posted on Dec 07, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 01, 2009
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Good day! I have a canon pixma mp228 and have "5100" error code. Please help. thanks Francis
Hello and Welcome to FixYa!
Error 5100 means that the cartridge can not be detected by the printer
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed but
If the problem is not resolved, then best option is to take it back where you purchased it or contact Canon service center about the error code or To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
They will surely solve it.
I hope this solution helps you
THANK YOU and Keep Visiting FixYa
May 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
To solve these follow the following steps. I hope it works
  1. Turn off printer
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
Please help me, i had a canon MX338 and MX328 software resetter
Hi
This error comes due to NV RAMof the printer. To diagnose this issue you'll need to reset the NV RAM of your printer, you can do that by entering the service mode. To do this turn on the machine. Press menu button the printer. Press scan button, then press copy and then scan button again to enter the service mode. Use > to go to NV RAM access. Set abs-m level to 0. Set abs-p level to 0. Press stop to exit.
This will resolve your issue. If still not resolved then try the above procedure by restarting it once.
Daniel Scott
Jun 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Service error 5100
Hi
Thanks for using FixYa. Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP190 Error Code 23
Hi ...
As you mentioned, you have already tried the basic troubleshooting which resolves the issue most of the time ... (good job) ... but sometimes there is a different issue altogether and to resolve the same, you need to get your printer repaired ... I would suggest you get a certified tech. to check your printer.
Cheers ...
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
When I try to print in my Canon Ip6210D, the alarm indicator flashes and the message of error 5100 appears in the screen. Could someone help me please?
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 11, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Ip4200 error code 5100
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) sometimes is not lubricated well enough from the factory.
Mar 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
350 people viewed this question
old marine
old marine
