Question about Garden
Weedeater featherlite model 952711334. need to replace fuel lines from fuel tank to primer pump. how do i remove fuel tank?
rockitman187
  • 2559 Answers
SOURCE: No fuel getting from fuel tank to fuel pump
It has a screen filter inside the tank that may have gummed up.If you drain the gas and look inside the tank,You will be able to see it.
Posted on Apr 05, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
#1 Taper
  • 1041 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
kapishtech
  • 2272 Answers
SOURCE: I have a Weedeater Featherlite
First check the voltage at spark plugs to coil and also check the coil to spark plug connections.Also check if the fuel is reaching to the fuel lines.Unplug the fuel pump and check if the fuel gets out of fuel pump.If yes then quickly reconnect the pump. Keep updated.Thanks.
Posted on Sep 16, 2010
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
Where do I find the model ### ?
The model number is the 952711334 This is an XT200 Featherlight manufactured in 2004
Jun 21, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I need a fuel line schematic for a WeedEater brand Featherlite Plus weedeater
Presuming the primer bulb is on top of the carb....Fuel filter line out of gas tank goes to the lower part if carburetor body. The other line (normally larger in size) coming out of the fuel tank goes to the primer bulb outlet on the top of carb.
If the primer/purge bulb is not on the carb, things are a little different. The fuel filter line out of the tank still goes directly to the carb, as the bulb will pull old fuel/air out of the carb allowing fresh fuel to flow in and pushes old fuel/air back to the fuel tank.
Fresh fuel in, old fuel out of the carb...you can hook up a piece of fuel line to the bulb and tell which one is pulling and which one is pushing..or depress it with your fingers on it...either way you can tell.
Jul 04, 2010 | Garden
Replaced gas tank and primer bulb on my Poulan Leafblower FL1500 and it appears I'm not getting gas into the carb. Any ideas as to what my be the cause?
I assume the new tank came with new fuel lines and filter in it.
First be sure you have all the lines hooked up correctly. There should be a main line from the tank ( has the fuel line on the end of it in the tank) to the fuel pump side of the carb. Then there should be a line leaving the metering side of the carb to the primer bulb then from the primer bulb returning to the tank. When you press the primer bulb you should see it **** the fuel into the carb then from the carb into the primer bulb then back into the tank.
If the fuel lines are all hooked up correctly then you should rebuild the carb.
Jan 02, 2010 | Poulan Featherlite Gas Blower, with Low...
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Featherlite FL 20 fuel line assembly
1 from filter in tank to carby 2 out of carby to primer 3 from primer back to tank
Jul 06, 2009 | Garden
The filter in the gas tank came off.
The filter should only fit in the end of one of the lines (probably the larger diameter one) The smaller line usually goes from the tank to the primer bulb and the larger one goes to the carburator. The filter just sticks in the end of the fuel line.
Jul 01, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
1,486 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
