Question about Husqvarna 28cc Gas Line Trimmer
Got a husqvarna 335r,when i fill it up with fuel it runs fine but when it gets to about 3 quarters of fuel left in the tank it begins to idle and i have to keep revving it to keep it goin then it dies on me but still have 3 quarters of fuel left in the tank,when i top it back up to the top it runs perfectly fine again untill it gets back down to 3quarters of fuel,,why is it doin this,help plz
  • 4,323 Answers
Hi
This is happening due to adjustment of fuel supply in carburetor. You can adjust the fuel supply and air/fuel mixture as well. To adjust the fuel supply check the setting of the carburetor. Settings means that the engine is adapted to local conditions, for example, the climate, altitude, fuel and the type of 2-stroke oil. The carburetor has three adjustment controls:
L = Low speed jet
H = High speed jet
T = Idle adjustment screw
The L and H-jets are used to adjust the supply of fuel to match the rate that air is admitted, which is controlled with the throttle. If they are screwed clockwise the air/fuel ratio becomes leaner (less fuel) and if they are turned anti-clockwise the ratio becomes richer (more fuel). A lean mixture gives a higher engine speed and a rich mixture gives a lower engine speed.
The T-screw regulates the throttle setting at idle speed. If the T-screw is turned clockwise this gives a higher idle speed; turning it anti-clockwise gives a lower idle speed.
For more details please refer page# 27 in the following manual---
Husqvarna 335r Reference/Operations Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 06, 2010
  • rapper x Aug 06, 2010
    hi daniel thnax for quick response,,,if its cutting out after using a quarter of fuel which way do i need to turn screws and which ones,,thanx again
  • Daniel Scott
    Daniel Scott Aug 06, 2010
    Hi
    You'll neeed to turn L and H screws, if they are screwed clockwise the air/fuel ratio becomes leaner (less fuel). Please check the manual for the diagram(check page# 27)--
    And, if you want to change the throttle setting of idle speed then you can change the T-screw setting. If the T-screw is turned clockwise this gives a higher idle speed; turning it anti-clockwise gives a lower idle speed.
    Daniel
The petrol gauge, from empty to quarter how much litres is it? And from quorter to half? From half to three quarter? Lastly from three quarter to full?
how would we even begin to guess at this . having no idea as to a make model year etc,etc . try calling a local dealer .
Jul 16, 2016 | Cars & Trucks
Nissain Terrano Runs pourly when under quarter of a tank of diesel but fine when over quarter
the fuel tank may need cleaning, sediment appears to be blocking the pick up tube when tank is at quarter, or the pick up tube may be broken at that height and the system cavitates at 1/4 tank
Apr 08, 2014 | Nissan Terrano Cars & Trucks
When my 2006 Pontiac Montana SV6's fuel gauge gets to about a quarter or a little less of a tank the van dies and will not start until 3 gallons of gas is put in the tank. Then it will start right up. It...
Sounds like at 1/4 reading,the actual reading of the fuel should be empty.Your gauge sending unit in the tank is most likely defective.Many are on these.
May 29, 2017 | 2001 Pontiac Montana
1992 eldorado fuel gauge reading LO when there is a quarter of tank left instead of the range
In almost every case I have seen this is caused by a defective fuel level sending unit inside the gas tank. You will need to remove the fuel tank from the car to replace it. The car must be raised as high as possible to access the tank straps and fuel lines, you will need a special tool to release the fuel hoses from the tank nipples. Be careful there is a high potential of fire here and have had one catch on fires twice in my life. Always support the car on safety Jack stands, also discinnect the battery negative cable before starting work. The part is about $150.00 and 3 hours to install with help from a friend.
Oct 08, 2012 | Cars & Trucks
I am having trouble with my husqvarna 61 .after running for about 10 minutes the machine stops revving as if it has run out of petrol, blip the throttle and it picks up again for a few seconds.any ideas?
Check to see if your tank vent is plugged.Fill tank full of fuel and run saw till you start to hear saw having problems,when this happens loosen fuel cap and see if it helps.Loosening the fuel cap will let air back into the tank if your vent is plugged.
Feb 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 137 Chain won't stop when idleing. I turned the T screw down just enough to keep it running chain keeps on going. Could it be the clutch?
your carburator is gummed up. Get some carb. cleaner additive for your fuel, run a couple of tanks of treated fuel through the saw and it will be ok.
Feb 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Everytime I run my car low on fuel then add more,whether I fill it up or not,it starts missing and the 'service engine soon' light comes. WE thought it was something to do with the firing system at first...
You've got water in your tank. There are fuel additives that remove water from the gas tank that work very well. As you run the tank low, all the water and other "junk" that collect on the bottom of the tank are now being injected into your fuel line, causing erratic idling and occasional misfires.
May 07, 2009 | 1996 Pontiac Firebird
Car won't idle after I gas up
hi there! sorry to say you got a sonata!! i was a master tech 4 hyundai! check your fuel pressure? replace fuel filter and check the release valve on the the fuel filler neck and the fuel tank breathers.
many thanks
Dominic Hill
Dec 10, 2008 | Hyundai Motor 2004 Sonata
Won't run at three quarters of a tank
air vent in filler cap blocked
Oct 21, 2008 | 1996 Chrysler Cirrus
Husqvarna 28cc Gas Line Trimmer Logo
175 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
