Question about Amana Refrigerators
Amana refrigerator, Model SZD23VW purchased 10/02/1999 stopped cooling. The contents have been moved to another refrigerator. It turns out that the beverage chiller control had been inadvertently turned to the coolest setting. We turned the control back to the middle position, the refrigerator started to work again. Without my knowledge, the beverage chiller control was turned to the warmest setting and the refrigerator stopped cooling again. I have cleaned all the coils and the entire refrigerator. The lights are all working and the water is coming out of the dispenser. The beverage chiller control has been returned to its original middle position, but the refrigerator does not seem to be cooling again. The refrigerator is in excellent condition, has been well cared for, and has always worked fine up to now.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
Maytag317
  • 1136 Answers
SOURCE: Amana refrigerator not running but light and water dispenser work
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jun 14, 2009
SOURCE: On the inside refrigerator temperature
most often the lowest number is the warmest setting, and the highest number is the coldest setting.
Posted on Dec 10, 2010
SOURCE: Amana AFI2538AES The refrigerator portion keeps
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Posted on Apr 30, 2011
Amana refrigerator not cooling, what should be done or what should we check to determine the problem?
The purpose of a refrigeration circuit is to move heat from the inside of the cabinet to the outside.
The compressor pumps refrigerant around the circuit and if everything is ok the evaporator is cold and the condenser becomes warm. If the compressor is running but nothing inside or outside is happening either the compressor is defective or the refrigerant has leaked away.
If the condenser is warm or hot but the inside is not cold the defrosting panel might be permanently switched on.
Nov 27, 2017 | Amana Refrigerators
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
My in-laws Amana ATB1832AR Top Freezer has stopped cooling. It was purchased 7/1/2005. Is there an inline fuse for the compressor that may have gone out?
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My Amana ARB2557CSL has no inside light or cooling
call a repairman there is no reset button for them. you need to call as soon as you can so your food wont spoil
Jan 21, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
100 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
