Question about Kodak EasyShare M883 Digital Camera
I have an M883 Digital Camera, and when I plug the USB cable into the computer and connect it to my camera to turn it on, the little green light below the "review" button blinks but the camera won't turn on. What's the problem? I've checked and the USB cable is plugged in fully and so is the connector for the camera, also the battery is in the right way as well.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 30, 2011
Kodak M883 will not accept charge when plugged to computer and will not go on either when plugged to computer.
Not all computer USB ports put out enough current to charge batteries.
If you're connected through a hub, try bypassing the hub and connecting directly to the computer. If you have another USB port available, try that. If you have a USB charger that plugs into a power outlet, try that.
Feb 15, 2014 | Kodak EasyShare M883 Digital Camera
Coolpix P80 camera doesn't turn on when I plug in the data cable?
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Mar 28, 2013 | Nikon COOLPIX P80 Digital Camera
My Kodak easyshare m883 won't import my pictures to my computer anymore. when I plug it the USB cord, usually a window pops up and asks if I want to import but not anymore. I went to 'my computer' and...
Jan 24, 2011 | Kodak EasyShare M883 Digital Camera
I have the kodak easy share M883 . can you guide me on how to transfer pictures from camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jan 13, 2011 | Kodak EasyShare M883 Digital Camera
My Kodak M883 digital camera is not charging I connect USB to the computer it wont charge Please help me as soon possible. Thanks.
HI dear, make sure the usb plug is fully inserted.Be patient,
If it doesn't work, buy an adapter directly plug into your wall power outlet.
Jan 20, 2010 | Kodak EasyShare M883 Digital Camera
My kodak C160 9.2 mp digital camera turns off when i connect it to my computer with the USB cable and there is not any light (flashing green or any kind at all) on the camera. My Computer is not detecting...
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak EasyShare M883 Digital Camera
M883 plugged into usb port does not seem to be charging
When charging from the computer the camera needs to be turned off. If the camera is turned on the camera is using it's power trying to transferre pictures over to the computer.
Nov 22, 2009 | Kodak EasyShare M883 Digital Camera
The camera shuts off when plugged into computer.
The LCD switches off automaticly, but the cam should still be on in order to transferre.
You should be able to see a flashing green light.
In order to charge thru the comp pls. switch the cam off before connecting to the comp.
Oct 28, 2009 | Kodak EasyShare M883 Digital Camera
I took a video using my camera easyshare M883 and i was wanting to know how I can download my video to my pc or e-mail to myself or something so I can get it on here
Hi Jen,
You should be using the software that came with the camera and a usb cable with a usb adapter to download the video to your pc. Install the software on your pc and open it up. Turn off the camera and plug the usb cable to the pc and the other end to the adapter. Plug in the adapter to the camera bottom. Then turn on the camera, should work like a charm. Thanks for coming to FixYa and have fun with your camera!
Rob
Nov 29, 2008 | Kodak EasyShare M883 Digital Camera
"check connections"
I am having a similar problem. I put mine in its dock, connected the USB cable to my computer, and pressed the USB button on the dock. The light turned green and after 30 or so seconds, the message Check Connections came up on the camera.
Apr 24, 2007 | Casio Exilim EX-S500 Digital Camera
Kodak EasyShare M883 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
