Question about D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204)
I have the D-Link ADSL 504T router. The internet is often go up and down - I often can't access the internet although there is connection. The only solution for that problem I found is to disconnect the router from the power and re-connect it again (sometime there is a need to perform it several times until the internet is reconstructed). What else can be done? Is it router problem and I should replace it? Thanks for the help
CLUEPATEL
  • 138 Answers
SOURCE: D-Link adls modem - interference with telephone
Yea this type of happen with most of DSL users! This is due to weak signal telephone line. You should only have 1 phone and 1 internet connection. You should remove all other telephones in the home. Then it will work fine. If you only have 1 phone then you must call the phone service person who will check that status of your wire. Might be your wire is old so it creates a problem. Then replace it the you'r done.
Posted on Dec 11, 2007
marked
  • 6487 Answers
SOURCE: Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
Posted on Oct 12, 2008
lalaro_me
  • 135 Answers
SOURCE: The internet connection keeps disappearing.
Change the router's IP address to (192.168.10.1) maybe you have an IP conflict between the modem and router.
Posted on Mar 16, 2009
  • 742 Answers
SOURCE: The D-Link Modem will not stay connected for
Is your unit old or new? Basically, there could be other factors giving you that intermittent disconnection from the internet. One is your ISP's internet connection that could be intermittently cut, or your browser refresh rate. Check out this two before you can conclude that the router is the problem. First change your browser to Mozilla Firefox. We had experienced the same problem with Google Chrome and IE not too long ago. If all browsers behave the same, then try to ask your ISP regarding your DSL issue.
Posted on Nov 06, 2009
puertobori
  • 7733 Answers
SOURCE: we are using D-link DIR
G to D-Link - TechSupport FAQ
Posted on Oct 29, 2010
D-Link DSL-504T driver disc missing, looking for Win 7 compatable driver for modem.
No driver needed since you aren't connecting the pc the the modem, but to the router.
Connect the pc to the D-Link DSL-504T with a LAN cable, access it from a browser by going to this IP - 192.168.0.1 - , in there access the modem settings and configure it accordingly.
Jun 20, 2011 | D-Link SWT DSL-504T ADSL MODEM with 4...
Hi, I have a DSL-504T ADSL router that has been running without any problems for some time. I just bought a wireless Dl-624S router. I have been unable to connect the wireless router to my ADSL router.I...
Freind,
You should have a look on manual, if you don't have just goto the manufacturer's site and download a manual for your product.
I think it will help you in a better ways.
Thanks
Iqbal
Apr 22, 2008 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
DSL-504T Router - not connecting?
Try using the D-Link Click'n Connect Utility.
Admin is the correct code for both the user name and password.
10.1.1.1 is the correct IP address for the setup page.
You may need to reset the router again by holding the reset button in for 30 seconds until the lights flash off then on.
Here is the setup manual:
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_GenII_QIG.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 04, 2009 | D-Link DSL-504T Router
Connecting to the internet
I was missing the NIC driver.
And got the answer off a free site :)
ciao
Sep 04, 2008 | D-Link SWT DSL-504T ADSL MODEM with 4...
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
http://192.168.0.1
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Pluging in
Rather than me repeating them, this same question has been answered several times on FIXYA. I would copy
and paste it in the FIXYA search on top of page to find several answers.
Dec 25, 2017 | D-Link SWT DSL-504T ADSL MODEM with 4...
Lan connection
Device your needing:
1. Modem
2. Router
3. Hub / Switch
4. UTP cable
5. RJ45
I'm sure you have a modem, right? First you need to have a router. The manual on your router will teach you how to connect to LAN, you just follow the instruction.
For cabling instruction and other info. just e-mail me ragutz2002@yahoo.com
I can't put all the details here..
Nov 10, 2007 | D-Link SWT DSL-504T ADSL MODEM with 4...
D-Link SWT DSL-504T ADSL MODEM with 4 Ethernet Ports (790069265204) Logo
110 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
